727 trans mount
willard77
Posted 2020-05-02 10:48 PM (#597674)
Subject: 727 trans mount
I'm installing a 1966 model 318 poly and tf 727 into my 1958 plymouth. My question is what transmission mount will work with this combo? The factory 58 transmission mount holes don't line up with the 727 holes(about a half hole off) and I don't really want to make the holes bigger, seems like there might be a better option out there. Thanks in advance.
Mopar1
Posted 2020-05-03 3:59 PM (#597711 - in reply to #597674)
Subject: Re: 727 trans mount
20001000100252525
When I put a 727 in my '60 Plym., originally a stick, I cut off the horizontal piece of plate with the coil spring mount on it & welded in 2 verticle plates & used a cross bolt thought the truck droop loop style tranny mount. In your case maybe have someone weld up the holes & redrill.
willard77
Posted 2020-05-03 9:05 PM (#597725 - in reply to #597674)
Thanks mopar1 for the reply.
