1955 1956 clutch rod needed
tailfins
Posted 2020-03-20 8:43 PM (#595809)
Subject: 1955 1956 clutch rod needed
1000500100100252525
missing part that mates up to clutch fork on my dodge coronet..can anyone help?
Posted 2020-03-20 9:22 PM (#595811 - in reply to #595809)
Subject: RE: 1955 1956 clutch rod needed
500020002000500100100100100
tailfins - 2020-03-20 5:43 PM
So you have this
https://www.ebay.com/itm/NOS-MoPar-1955-58-Plymouth-Chrysler-Dodge-D...
BUT you are missing one of the many other linkage parts? Which one?
(55-56ClutchPedalPartDiagram.jpg)
Attachments 55-56ClutchPedalPartDiagram.jpg (152KB - 260 downloads)
tailfins
Posted 2020-03-22 8:19 PM (#595884 - in reply to #595809)
Subject: Re: 1955 1956 clutch rod needed
1000500100100252525
the first one that attaches to the fork
Posted 2020-03-22 11:34 PM (#595893 - in reply to #595884)
tailfins - 2020-03-22 5:19 PM
Work with me here. The 6-24-1 one or the 6-50-1 one? If you can point out the reference in the diagram, I can look up the PN and then search the internet for that part.
Edited by 56D500boy 2020-03-22 11:36 PM
tailfins
Posted 2020-03-23 11:23 AM (#595913 - in reply to #595809)
1000500100100252525
those 2 as well as -23...thanks
Posted 2020-03-23 2:56 PM (#595925 - in reply to #595913)
tailfins - 2020-03-23 8:23 AM
I think that the parts you seek are 1409 763 and 1610 972 (see below). I didn't get any good hits via Google, or Mopar Mall or Hilltop so I think you might have to go used from Big M or French Lake Auto Parts or?
Otherwise, you might have to get creative and use aftermarket heim joints to create the link that you need.
There are lots out there:
https://www.summitracing.com/search?SortBy=BestKeywordMatch&keyword=...
https://www.amazon.com/slp/heim-joints/vqhsc99oewx33wr
*OR* really go nuts and modify a 8.5" Adjustable Tensioning Rod Heim Joint Alternator Bracket:
https://www.amazon.com/Team-Performance-Adjustable-Tensioning-Altern...
(55-56DodgeClutchRodPNs.jpg)
Attachments 55-56DodgeClutchRodPNs.jpg (145KB - 271 downloads)
Old Ray
Posted 2020-03-23 6:38 PM (#595937 - in reply to #595809)
500
So that reads that Plymouth is different then Dodge ? And therefore the ones that are out of my '56 PLODGE (Canadian) 3 speed V 8 will not work?
Probably can't find them anyway.
NM Desoto
Posted 2020-03-23 8:12 PM (#595939 - in reply to #595809)
Brewer's Performance repops many of the sixties clutch adjuster kits. Some are adaptable to the older cars. Also, Dodge trucks
used very similar parts for many years, check with your local salvage yards.
