Sealant on new exhaust studs 325 hemi?
Brushwolf
Posted 2020-02-15 12:44 AM (#594294)
Subject: Sealant on new exhaust studs 325 hemi?
100100252525
Noticed at least some of these studs go straight thru head into rocker area. Have all new ones from HHH to install and wondered what is best sealant/thread locker to use on the threads going into head? Have a variety of sealers and locking compounds on hand, but not sure which to use. I am using the stock exhaust manifolds.
Thanks, Mike
Mopar1
Posted 2020-02-15 9:55 AM (#594302 - in reply to #594294)
Subject: Re: Sealant on new exhaust studs 325 hemi?
2000100025
The others go into water, @ least on the Chr. Tube of copper coat, best I recall.
Posted 2020-02-15 10:52 AM (#594304 - in reply to #594294)
5000200020005001002525
I used the gray silicone gasket maker. It has worked very well with no leaks. But I didn't seal the old studs thinking that they were already good. Wrong. I now have a leak on one of them that I never touched. I'm sure it will seal itself again eventually since it is very minor.
