New Heater/ Defrost System
no_jive55
Posted 2020-02-09 1:23 PM (#593980)
Subject: New Heater/ Defrost System
I am restoring a 1960 Plymouth station wagon and I am getting to the point where I am setting up the heat/ defrost system. At some point in the car's life someone took a hammer and bashed in the cardboard ventilation system under the dash in order to make room for an aftermarket AC unit. So I have nothing to work with or go off of as a reference. I was considering purchasing a Vintage Air unit that is just heat and defrost https://www.vintageair.com/heater-only/#. I'm not going to have AC, just heat and defrost. Is this a good way to go with the Vintage Air unit? Does anybody have another system that they have used?
Also, I was considering routing the ventilation system to the rear of the wagon so that I could defrost the rear window. Has anybody seen a set up like that? If so, how was it executed?
Edited by no_jive55 2020-02-09 4:40 PM
