Wiring Harness
no_jive55
Posted 2020-02-09 10:11 AM (#593976)
Subject: Wiring Harness
I am restoring a 1960 Plymouth station wagon with a heavily damaged wiring harness. 40% of the harness has been monkeyed with (at some point someone added a trailer light plug, AC, fog lights, home made voltage regulator, and a lot of other mess). The other 60% of the harness is cracked with wires cut or missing connector ends. The current harness is basically trashed. I was looking to totally replace the harness, and update to a harness with fuses, electronic ignition, and alternator. So far the best option that I have found is this Painless 1966-76 Mopar Harness https://www.painlessperformance.com/wc/10127.
Has anyone else had to replace their entire harness?
What suggestions do y'all have?
Just curious, does anyone know why the original harness had no fuses?
Posted 2020-02-09 1:23 PM (#593981 - in reply to #593976)
Subject: Re: Wiring Harness
20002000100100252525
i went with the ezwire 21... looks very similar. I need for electric fuel pump, electric fans etc.. My harness was also totally jacked. Im converting to volt meter also.
http://rover.ebay.com/rover/1/711-53200-19255-0/1?ff3=4&pub=5575495...
Posted 2020-02-09 1:24 PM (#593982 - in reply to #593976)
I also got xtra long due to worry about the rear tail lights. I like the painless stuff, I am going to do some documentation on mapping as that will be the pita...
it had no fuses because it was 1957 ... people didnt put giant speakers, electric fans, electric fuel pumps, crazy dvd players and aftermarket stereos with amps in their cars
they had some cirbuit  breakers on various parts.
Edited by mikes2nd 2020-02-09 1:32 PM
willard77
Posted 2020-02-10 7:38 PM (#594039 - in reply to #593976)
I bought a f.s.m and all the correct color and guage wires and built my own. The total harness only cost me about 200 dollars.
71charger_fan
Posted 2020-02-11 9:52 PM (#594101 - in reply to #593976)
500100
I was very happy with the American Autowire harness that I installed in my '55 wagon.
58Jackie
Posted 2020-02-15 9:44 PM (#594338 - in reply to #593976)
Yeah i need to replace the whole front to back wiring harness on my 58 Belvedere. The wires are so brittle from age I'm worried about just moving them around will snap them. Also its been spiced at the lighting spots cause my car has been converted to 57, and then back to originality as a 58 again. I'm probably going to get the universal 21 circut for Mopars by Painless wiring harnesses. About 500 bucks, not too bad.
These cars (also other makes in the 50s) dont have fuse boxes. Personally, i think its unsafe to not have a fuse box, its like just asking for shorting out/possible electrical fire to happen. Fuse boxes started in the 60s. Just another reason why i want that new wiring harness so bad, it has a fuse box in it.
Edited by 58Jackie 2020-02-15 9:50 PM
Posted 2020-02-15 10:22 PM (#594340 - in reply to #593976)
50001000
Jackie: this video is good to watch even though you are installing a new harness. He is an automotive instructor and car restorer. Yes, the accent is thick, but after a few minutes you will get used to it. The steering wheel video that he made this year is good also.
https://www.youtube.com/watch?v=Ws7tm-KdCzY
58Jackie
Posted 2020-02-16 12:28 AM (#594345 - in reply to #594340)
mstrug - 2020-02-15 9:22 PM
Wow, i sure wasnt expecting to see that 57 Plymouth! Went to the video, thinking it was of some other car rewiring. When i saw that 57, i'm sure i jumped. Thanks Marc, saved this video, should help me out when i get to this stage.
