| Hi guys, I used to be able to go to my search engine and just enter, "what is the block height or deck height on a 440 Chrysler engine" and would get a handful of links and the answer to my question in a few seconds. Now it's a mess.
I'm wondering if any of you guys have old engine manuals or links to resources that I could use.
I'm gathering parts for our next race engine for this summer and am in the process of ordering a set of BME pistons and rods right at the moment.
I'm using a set of Stage V Hemi conversion heads on a .060 over 440 block and the 4.15" stroke crank. I can say for sure the heads haven't been decked because I CC'd them but the block on the other hand I can't say for sure it's not been decked. It would kinda suck to find out it has been after the pistons were already made.
I used to be a member of a few different Mopar racing discussion forums but they've all gone dark by now.
So any info or links would be awesome,
Thanks,
Wayne |
Location: WHEELING,WV.>>>HOME OF WWVA | pull the heads and measure with a straight edge across the hole down to the piston . this is 100% the only way to go to be 100% sure what ya got ---------------------------------------------later |
Location: So. Cal | The advertised deck height is 10.725", but as Chuck stated, it's difficult to measure accurately. You really need to mock it up and find out.
http://victorylibrary.com/mopar/deck-height.htm |
Location: Peoples Republic of Oregon | Agreed. Published specs are not always 100% accurate for 100% of the time. |
Location: WHEELING,WV.>>>HOME OF WWVA | Agreed. Published specs are not always 100% accurate for 100% of the time.
like my 383 pistons being .094 in the hole . if i remember the compression ratio was @7.8 -----------------------------------------later |
