WTB: dodge hemi spark plug wire cover Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
hondaman1974 |
Veteran Posts: 189 Location: Northern Illinois | hi, looking to buy 1 dodge hemi spark plug wire cover. should fit 241 270 315 and 325, please correct me if im wrong. thanks in advance!!!! | ||
wildone770 |
Extreme Veteran Posts: 327 Location: phoenix az | HI I HAVE THIS IN AZ PLEASE CALL DON 602 6899414 THANKS | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | hondaman1974 - 2019-12-18 9:14 AM hi, looking to buy 1 dodge hemi spark plug wire cover. should fit 241 270 315 and 325, please correct me if im wrong. thanks in advance!!!! You might want to be more specific. The 315 hemi covers have relief slots for the bumps on valve covers needed to accommodate and clear the adjustment screw for the exhaust solid lifter rockers. The 325 was hydraulic lifter but Dodge reused the 315 stuff. They might fit on a 241/270 but they wouldn't look right. 241/270 covers won't fit on a 315/325. Edited by 56D500boy 2019-12-18 11:19 PM | ||
hondaman1974 |
Veteran Posts: 189 Location: Northern Illinois | thanks dave, as you know its a learning experience!! | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | hondaman1974 - 2019-12-19 6:21 AM thanks dave, as you know its a learning experience!! Yep. I am still learning too. Here is an example of the 56/57 315/325 Dodge hemi valve cover (during stripping and repainting) showing the rocker clearance bumps: And the corresponding 315/325 Dodge hemi spark plug wire covers with the notches for the rocker clearance bumps on the valve covers And the two together, in place: | ||
arizona mopar gold |
Extreme Veteran Posts: 509 Location: Whetstone, Arizona | You'll need to state which side you need also..Left or Right?....they do not swap over to the other sides, because of the rocker bumps and end gaps for the wires to pass through | ||
hondaman1974 |
Veteran Posts: 189 Location: Northern Illinois | thanks for the advice, I should have stated my engine is the 270 hemi which doesn't have the bumps, I thought the dodge hemi"s were all the same and the Chrysler and Desoto engines had the bumps. I learn something new every day!!!! | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | hondaman1974 - 2019-12-20 9:22 AM thanks for the advice, I should have stated my engine is the 270 hemi which doesn't have the bumps, I thought the dodge hemi"s were all the same and the Chrysler and Desoto engines had the bumps. I learn something new every day!!!! I'm always learning too. Hopefully not too much RE-learning This is the cover(s) you are looking for on this early build 55 Dodge Custom Royal 270 2 bbl hemi (embossed valve covers = early(ish) build): Edited by 56D500boy 2019-12-21 8:02 PM (55Dodge270HemiSuperRedRam.jpg) Attachments ---------------- 55Dodge270HemiSuperRedRam.jpg (156KB - 133 downloads) | ||
