Mirror Matic HELP ?
Daniel 1959
Posted 2019-12-17 8:23 AM (#591725)
Subject: Mirror Matic HELP ?
Today my Mirror Matic Mirror package from Sweden arrived with a 1959 stile Mirror Matic Mirror. Unfortunately the electron tube with 7 pins was broken, maybe during transport.
The only word and number I can read is TUNG-... and a number 3225906-..
Can somebody identify the part, if this still exists, i would like to replace it or if somebody has a work around with modern parts I would be very happy
Thank you all
Dani
Posted 2019-12-17 8:54 AM (#591726 - in reply to #591725)
Subject: Re: Mirror Matic HELP ?
500050002000100025
RCA 12K5 for instance or GE 12K5
https://www.ebay.com/itm/12K5-GE-tube-vintage-working-Radio-tube-as-...
Daniel 1959
Posted 2019-12-17 2:51 PM (#591740 - in reply to #591726)
wizard - 2019-12-17 8:54 AM
Whow that was Quick !
Thanks a lot.
Anybody knows about the Resistor rating of Highway or City position.
I asume the poti's are beond their live cycle ,, couldn't get a valuable reading when tested...
Dani
Posted 2019-12-17 3:47 PM (#591746 - in reply to #591725)
500050002000100025
Just wait until you get the replacement tube Daniel. They normally work even after all those years. Mind that there's a "warm-up" time before the mirror works.
Connect the mirror to the "H" terminal on the light switch with an additional toggle switch (I beleive you have the "dipped beam law" during daytime as well as we), otherwise the mirror will be "hot" all the time which is bad for the mirror.
Daniel 1959
Posted 2019-12-17 4:42 PM (#591752 - in reply to #591746)
wizard - 2019-12-17 3:47 PM
Tank you Wizard,
Yes we have now the same law in Switzerland. i will sure consider to put a swich between it.
shall I also put a fuse to it , thought about 5 or 10 amps ?
Dani
Posted 2019-12-18 2:25 AM (#591767 - in reply to #591725)
500050002000100025
Try with a 5 Amp fuse first Daniel
(Mopar Mirror-matic.jpg)
Attachments Mopar Mirror-matic.jpg (139KB - 258 downloads)
di_ch_NY56
Posted 2019-12-31 7:57 AM (#592293 - in reply to #591725)
Subject: RE: Mirror Matic HELP ?
100050025
In mine, also a 1959 MirrorMatic is the coil broken (the fine wire respectively). I do not get an Ohm value between the two posts of the coil....
