1956 Plymouth 277 4-barrel motor & powerflite trans
   Forward Look Swap Meet -> For Sale - PARTSMessage format
drtracer01
Posted 2019-11-06 11:35 AM (#589813)
Subject: 1956 Plymouth 277 4-barrel motor & powerflite trans
I have a running 1956 277 motor for sale. Pulled out of car already, has the factory 4-barrel option. Motor appears to be all original except for water pump. One cylinder has low compression. Transmission shifted into all gears properly.
$250 for motor
$200 for transmission
I can sell individually or together.
Posted 2019-11-06 2:42 PM (#589817 - in reply to #589813)
Subject: Re: 1956 Plymouth 277 4-barrel motor & powerflite trans
5000200020005001002525
Do you have the air cleaner as well? Can you post a picture of it?
drtracer01
Posted 2019-11-06 2:57 PM (#589818 - in reply to #589817)
Sorry I do not have the original air cleaner, it has been swapped with something newer.
(20190828_172938.jpg)
Attachments 20190828_172938.jpg (140KB - 86 downloads)
Posted 2019-11-06 9:15 PM (#589828 - in reply to #589813)
Thanks.
Finsinthemirror
Posted 2019-11-06 11:38 PM (#589834 - in reply to #589828)
I just thought I'd say that the factory cast iron 4 bbl intakes sell for $350-450 (sometimes higher) alone and yours looks like it has the factory carb too. Just food for thought. Good luck with your sale!
Posted 2019-11-07 2:47 AM (#589836 - in reply to #589817)
Powerflite - 2019-11-06 11:42 AM
Based on this page from the 56 Fury brochure, I would think that a 4 bbl 277 might also have the same air cleaner, i.e. the same as any 56 Chrysler 4 bbl.
But I could be wrong.
Posted 2019-11-07 9:25 AM (#589843 - in reply to #589813)
Subject: RE: 1956 Plymouth 277 4-barrel motor & powerflite trans
Yes, Dave, but how was it painted on a '56 Savoy or Belvedere? It wasn't painted the same as a Chrysler or Fury. I'm guessing it was painted in similar fashion as the corresponding 2bbl air cleaners, but I would like to see an original one with my own eyes. All the pictures I can find have been re-done, and who knows if they were originally like that?
(56 Belvedere 277.jpg)
(56 Fury 303 Engine.jpg)
(56 Belvedere 270.JPG)
Attachments 56 Belvedere 277.jpg (126KB - 107 downloads)
Attachments 56 Fury 303 Engine.jpg (132KB - 106 downloads)
Attachments 56 Belvedere 270.JPG (244KB - 91 downloads)
jboymechanic
Posted 2019-11-07 9:36 AM (#589845 - in reply to #589813)
2000100252525
Great price for the motor given it has the 4 barrel intake.
PowerFlites are hard to sell at any price, most people want to upgrade to the TorqueFlite and if they already have a PowerFlite they're pretty darn reliable.
Posted 2019-11-07 12:10 PM (#589858 - in reply to #589843)
Powerflite - 2019-11-07 6:25 AM
Okay. I understand. But finding a 56 Plymouth with a 4 bbl that is unmolested is probably like looking for a photo of a Sasquatch riding a unicorn.
If P28 = 56 Plymouths with 6 cyls and P29 = 56 Plymouths with V8s. SO if Power Pack = 4 bbl carb and dual exhaust, there is only one PN for air cleaner for the P29s with the 4 bbl V8s, including the Fury, i.e. they might all have been gold (?).
As a side note: in looking at these PNs, I see the 56 Dodge D500 air cleaner PN is shared with the D63-1 (Coronet) with the Power Pack. Interesting, I have seen a D63-3 Custom Royal 315 poly Power Pack with a red air cleaner but thought that red was exclusive to the D500. That could further suggest that the gold 56 "Fury" 4 bbl air cleaner might not have been exclusive to the Fury either.
Edited by 56D500boy 2019-11-07 6:15 PM
(56PlymouthAirCleanerPNs.jpg)
Attachments 56PlymouthAirCleanerPNs.jpg (160KB - 97 downloads)
drtracer01
Posted 2019-11-08 2:22 PM (#589918 - in reply to #589834)
Finsinthemirror, thanks for the info on the 4 bbl intakes, i did not realize they were quite the piece. Being down in Louisiana i figured i would have difficulty selling the motor, maybe i would have better luck just selling the intake and carb so i can ship.
Finsinthemirror
Posted 2019-11-08 6:40 PM (#589928 - in reply to #589918)
No problem. You might want to do some research first before you sling the intake and carb by itself. Sometimes there are differences (possibly heads, cam, distributor) in the motors of 'power pack" 4bbl twin exhaust equipped cars but I'm not 100% sure about that. It might be worth looking into since it isn't the ordinary 2 bbl single exhaust version
drtracer01
Posted 2019-11-09 12:49 PM (#589954 - in reply to #589813)
I do believe i need to re-evaluate my listed price, may also go ahead and rebuild the carb. The input and knowledge on this forum is amazing and appreciated.
Posted 2019-11-09 2:14 PM (#589959 - in reply to #589954)
drtracer01 - 2019-11-09 9:49 AM
If you do decide to rebuild the Power Pack carb, you might want to confirm the Carter number, e.g. 2302S (or SA), and then check out this posting:
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=72553&...
or buy the Carter WCFB Service Manual CM448 which is available as a 375 page pdf from the Carburetor Doctor (and others?):
https://www.carbkitsource.com/manuals/cm448.html
drtracer01
Posted 2019-11-10 12:46 PM (#589983 - in reply to #589959)
Thank you for the info 56D500boy
Posted 2019-11-10 1:40 PM (#589984 - in reply to #589983)
drtracer01 - 2019-11-10 9:46 AM
You're welcome
Hope it helps.
Posted 2019-11-10 3:18 PM (#589986 - in reply to #589928)
Finsinthemirror - 2019-11-08 3:40 PM
I don't see particular call-outs for Power Pack camshafts for 1956:
Edited by 56D500boy 2019-11-10 3:19 PM
(55-58CamshaftPNs.jpg)
Attachments 55-58CamshaftPNs.jpg (214KB - 102 downloads)
Fin_ish Floyd
Posted 2019-11-21 12:43 AM (#590477 - in reply to #589813)
Is your 277 still for sale? If so, where are you located in Lousiana? Please Email or call @ floydyouturn@Hotmail.com - Ph. 409-789-4064.
Thanks,
Floyd
