Need new tires....thoughts? Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
BrianD |
Regular Posts: 78 Location: Orland Ca | The 59 Windsor needs new tires....not much of a selection for 14 inch wheels. Thought about going to 15 inch rims but then the hubcaps won't work. Was considering aftermarket Torque thrust in a 16 inch size but would like to keep it stock. Currently has a narrow white wall but don't want to spend for wide whites. I will be driving it as I did 20 years ago, pretty much a daily driver, too much fun to just let it sit or drive it once in awhile. Any thoughts or recommendations appreciated Thanks, Brian | ||
57burb |
Expert Posts: 3967 Location: DFW, TX | From everything you already ruled out, it sounds like your only option is 14" radials with a black sidewall or a narrow white wall. You can get them at any tire store. 215/75-14 should be about right. https://www.ebay.com/itm/4-NEW-215-75R-14-HANKOOK-OPTIMO-H724-WHITE-... | ||
ABloch |
Expert Posts: 1476 Location: Pacific Northwest | ^^what Danny said^^ 215/75/14 | ||
BrianD |
Regular Posts: 78 Location: Orland Ca | Going to check with Discount Tires in the next town over this week and see what they have.. Les schwab's trying to get me to order from Coker some WWW but I don't want the upkeep as it will be somewhat of a daily driver..(and really don't want to spend the money) BTDT. Going to dismount tires, blast rims, and paint before putting new tires on. It has 225/75R14 on it now with a 1 inch or thereabouts (maybe 3/4, I'd have to measure) that were on it when I sold it in '96 so it's definitely time for new tires. There is a place in Sacramento that will cut a WWW into new tires and I have even considered to go that route, but wide whites have to look clean all the time, at least to me. I guess I could clean them every week when I wash it. | ||
58coronet |
Veteran Posts: 139 | Those 215/75R14 tires are going to look mighty small on the Windsor. Unfortunately not much choice in 14 inch tires. I replaced the old 215/75R14 tires on my '58 Coronet with new Goodyear Super Cushions in size 8.00x14 and the look and ride is so much better. Granted they are expensive and bias ply....but the larger diameter looks so much better and the speedometer is correct now. At least consider them before going with 215-14's. | ||
Expert 5K+ Posts: 5006 | these are 215/55/15 and they are puny (tire.jpg) Attachments ---------------- tire.jpg (239KB - 146 downloads) | ||
arizona mopar gold |
Extreme Veteran Posts: 509 Location: Whetstone, Arizona | I just put 4, 215/75/14 with white wall on my 57 Coronet...all up $352 out the door at Discount Tire | ||
mstrug |
Expert 5K+ Posts: 6498 Location: Newark, Texas (Fort Worth) | Cali has Radials for $140 for 215x75-14: http://callitw.com/index.php?route=product/product&path=1_4&product... They have other 14'' tires too... http://callitw.com/index.php?route=product/category&path=1_4 Edited by mstrug 2019-09-27 4:35 AM (cali2157514.jpg) Attachments ---------------- cali2157514.jpg (17KB - 177 downloads) | ||
Expert 5K+ Posts: 5006 | im going for some Vogue tires. 235/75/15 (05-ClassicWhite-Wide-High-Angle-(3-4)_1920px.jpg) Attachments ---------------- 05-ClassicWhite-Wide-High-Angle-(3-4)_1920px.jpg (275KB - 151 downloads) | ||
BrianD |
Regular Posts: 78 Location: Orland Ca | Ordered 215/75/14's from Discount tire. Price is more than right and at least I can hopefully be driving by the end of next week. I ran the Hankook 13's on my Corvair for a few years and they rode and handled and rode nice.. (yes, Corvair's do handle nice, forget Ralph Nader) so hoping they will work on the Windsor for awhile. Thank you for the links and suggestions. Brian | ||
BrianD |
Regular Posts: 78 Location: Orland Ca | I do like the looks of those Vogue tires though | ||
22mafeja |
Elite Veteran Posts: 649 Location: Finland | I put van tyres on my firedome 58. I like BWW tyres 215/80 R14 Green Max Linglong GreenMax Van 112/110R The height is really right ....big difference from 215/75-14...they are too low.. Edited by 22mafeja 2019-09-28 3:03 AM | ||
58coronet |
Veteran Posts: 139 | Interesting bit of info regarding Corvairs and their handling problems......Due to the extreme light weight on the front wheels due to the rear engine design, GM only called for 15 psi or so in the front tires. Folks would unknowingly inflate them to 30 psi or so, and the bias ply tires would handle like they were rolling on marbles. Nothing inherently wrong with the car's handling otherwise. | ||
Expert 5K+ Posts: 7393 Location: northern germany | 58coronet - 2019-09-28 8:26 AM Interesting bit of info regarding Corvairs and their handling problems......Due to the extreme light weight on the front wheels due to the rear engine design, GM only called for 15 psi or so in the front tires. Folks would unknowingly inflate them to 30 psi or so, and the bias ply tires would handle like they were rolling on marbles. Nothing inherently wrong with the car's handling otherwise. Well, rear engines cars are not as safe as front engine cars per se (has nothing to do with handling) and IIRC the corvair had a swing axle. One would think, since it is called IRS, better than a straight axle. This is not the case. Swing axle=worst suspension system in automobile history. Other storys I heard, it rolled easily since the bean counters omited the sway bar(s)? Anyway, the Corvair never appealed to me. Small 60s car? I'd have prefered a 1rst generation Barracuda with the crazy rear window. Why it wasn't a sale success like the (Imo) UGLY 64+ Mustang coupe, I'll never understand. Edited by 1960fury 2019-09-28 10:13 AM | ||
58 DESOTOS RULE |
Expert Posts: 2308 Location: The Bat Cave, Fairborn, OH | With proper inflated tires, the handing of the 1960-64 Swing axle Corvair was fine, so Nader did a disservice to the model calling it an easy flipper in his book. GM even redesigned the rear suspension for the 1965-69 model year, so it became a very stable car that performed well. GM decided to let the Corvair die though after the 1969 model year because they had another model in mind to replace it. | ||
BrianD |
Regular Posts: 78 Location: Orland Ca | Not to turn this into Corvair love or bashing topic, personally love them but here's a few thoughts. I have 16 in various states..parts to almost restored...most persons are ill informed or just ignorant of how advanced the Corvair was...more models offered than any car company of the time. Only production air cooled turbo (only beaten to market by Olds but there's didn't work. Wagons, vans, trucks, convertibles, coupes, sedans. I have a couple to a few of each Of eary and late models. Texas A&M in 1972 completely exonorated the early model suspension design of any fault. The later 65-69 IRS out slalomed the Corvette at GM proving grounds and its no wonder it was called the poor mans Porsche. My little 63 convertable 4 speed gets 24 MPH and is an absolute blast to drive. Probably would get more if I wasn't so hard on her. You either love them or hate them. AND I also love my big finned Mopars!! PS...A girl I went to HS with had a 64 convert she drove every day.She got in a head on collision when a drunk driver crossed the road one night.crushed the front end all the way to the gas tank...I wish I had taken pictures of it. She broke some ribs and had a hurt shoulder, spent the night at the hospital but basically walked away from a very serious accident. Her dad bought one of my parts cars and he and his daughter put the convert back together and she drove it for years after that. Seeing it made me a believer in the design and safety of the Corvair. Edited by BrianD 2019-09-29 1:15 AM | ||
BrianD |
Regular Posts: 78 Location: Orland Ca | Another thing...I think Don Yenko thought they were a pretty good race car. And Jay Leno and Tim Allen https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=... | ||
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | yenko was not far from where i grew up in western pa . once a friend of my dads had them do a custom paint on a dragster called the god father and a mopar , a swinger i think it was , anyhow if you saw the yenko shop you'd wonder where they got the money to build such great classics . not much more than a rundown chevrolet dealership ----------------------------------------------- later | ||
firedome |
Expert Posts: 3155 Location: NY & VT | Disagree on the 1st Turbo... the Olds Jetfire turbo V8 worked just fine, but you HAD to use the factory Jetfire fluid injection system (alcohol based) to avoid detonation. They were very reliable and effective. The all aluminum 215 cu in V8 was boosted from 150 to 165 hp and that same basic engine (Buick's version) was bought by Rover (the tooling) and produced by them from 1967 to 2004 !! . | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | 22mafeja - 2019-09-28 8:58 AM I put van tyres on my firedome 58. I like BWW tyres 215/80 R14 Green Max Linglong GreenMax Van 112/110R The height is really right ....big difference from 215/75-14...they are too low.. Could you please post a photo of those tires here? The bias ply tires 8.50 - 14 had an approximate diameter of 730mm (29") The 215/80 R14 should have a theoretical height of 215x80%x2+344 (14") = 699,6mm (27.5"), hence 1.5" too small (but acceptable). (IMG_4100-rez.jpg) (IMG_4101-rez.jpg) Attachments ---------------- IMG_4100-rez.jpg (118KB - 155 downloads) IMG_4101-rez.jpg (85KB - 141 downloads) | ||
normsclassicradio |
Veteran Posts: 298 Location: Kalispell, MT USA | I've been working these numbers for a while. My 61 Newport ran 235/75r15 tires, speedo seemed pretty close. I'm running 215/75r15 tires on my 64 880. Too small, speedo off by a fair margin. I just found this site: https://tiresize.com/comparison/ It lets you do a size comparison easily. Now I see that the 235/75R15 is close to the original 8.00-14 tires it came with, at 29 inches diameter. Cool site, also can calculate plus sizing like +1 for 16", +2 for 17". | ||
billy |
Extreme Veteran Posts: 395 Location: upstate new york | I put 235/75R15's Radials on my 57 New Yorker that originally came with 8.00-14's....Calli Tire wide whites (on Hankock's)....$100/tire cheaper than Coker and others...they ride nice... billy | ||
drosera88 |
Expert Posts: 1267 Location: San Antonio TX | If youre willing to spend the money, you can get bias ply look radials. Best of both worlds, 50's looks, radial handling. | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | And those ones have serious problems as well.... | ||
22mafeja |
Elite Veteran Posts: 649 Location: Finland | Hmm...my eyes lied to me...the 215/80-14 van tyres look big but when I measured them I was surprised...they are only 680 mm diameter. I think 8.00-14 is about 700mm so pretty close to that at least. (IMG_3515 (250mp).JPG) Attachments ---------------- IMG_3515 (250mp).JPG (70KB - 146 downloads) | ||
BrianD |
Regular Posts: 78 Location: Orland Ca | Tire height a little shorter than I wanted but still close to what was on it. They will work for now | ||
BrianD |
BrianD |
Regular Posts: 78 Location: Orland Ca | will post pictures when I can | ||
BrianD |
Regular Posts: 78 Location: Orland Ca | pics | ||
BrianD |
Regular Posts: 78 Location: Orland Ca | here it is (P1140245.JPG) Attachments ---------------- P1140245.JPG (115KB - 148 downloads) | ||
