1956 Fury Fuel Gauge Freakout! WTH?
ABloch
Posted 2019-09-06 12:04 AM (#587133)
Subject: 1956 Fury Fuel Gauge Freakout! WTH?
1000100100100100252525
Went to the gas station today and filled the tank. Pulled out and jumped on the freeway and I noticed the fuel gauge freaking out!
Never seen this before. I suppose it has to do with sending unit being over stimulated. Or something.....
https://youtu.be/gTypIs8xvWo
Posted 2019-09-06 1:44 AM (#587141 - in reply to #587133)
Subject: RE: 1956 Fury Fuel Gauge Freakout! WTH?
500020002000500100100100100
Like all our analogue gauges, they need a good 12V reference signal and typically a good ground. So your issue could be related to an intermittent voltage regulator issue or a flaky ground. Or something else, i.e. a flaky rheostat winding in the sender.
Good luck.
ronbo97
Posted 2019-09-06 3:14 PM (#587167 - in reply to #587141)
2000200025
Agree that it's a loose ground. I'll bet that if the car is standing still, it's not jumping around like that.
IIRC, it's grounded thru the tank. So I would bet that the sending unit is loose. There is a rubber O-ring that goes between the sending unit and the tank. Verify that that is in place and that it's holding the sending unit firmly against the retainer.
Ron
