heater / defroster fans rotation direction
hondaman1974
Posted 2019-07-20 4:36 PM (#585033)
Subject: heater / defroster fans rotation direction
100252525
hi, wiring my heater and defrost motors on my 55 dodge cr. I verified the heater motor (big cage) spins counter clockwise. I forgot to check my defrost motor (small cage) rotation. I assume the defrost motor spins clockwise, if you set the cages side by side the fins are opposite each other. the fsm does not specify this. btw it is a model 700 heater without a/c. thanks!!!!
