"59 Fury Fuel Inlet Tube Retention
1959SportFuryPaul
Posted 2019-07-11 9:16 AM (#584694)
Subject: "59 Fury Fuel Inlet Tube Retention
New User
I have a fuel tank question regarding my '59 Fury. I removed and cleaned the original tank. When I returned it to the vehicle and hooked up the inlet filler tube I noticed the tube freely moved upward toward the fuel door. I opened the door and the tube has the large black rubber grommet intact and I can move the tube in/out or up/down easily. If there a clamp that should be installed where the tube enters the tank or is there a connection between the inlet tube and the larger tube that in visible in the trunk? It feels like the inlet tube could easily pull out of the tank in an accident. The rubber inlet o-ring at the tank is good and installed. I lightly oiled the o-ring to aid in inserting the tube. Thank for any thoughts, Paul
Posted 2019-07-11 10:08 AM (#584698 - in reply to #584694)
Subject: RE: "59 Fury Fuel Inlet Tube Retention
5000200020005001001001002525
You might want to review this thread:
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=69812&...
