Axle Bearing Question
Alex
Posted 2019-06-05 12:39 AM (#582943)
Subject: Axle Bearing Question
10010025
Hi Guys, As I am changing the bearings, I notice my 1961 Chrysler Newport diff oil level when full, sits below axle tunnels and do not see how it would lubricate the rear axle wheel bearings.
I have read that the bearing are just grease packed, is this true?
The old ones had no grease on them.
Do I just grease pack the new ones?
Do I get sealed bearings?
Or will the oil lubricate them?
What to do?
58coupe
Posted 2019-06-05 10:17 AM (#582954 - in reply to #582943)
Subject: Re: Axle Bearing Question
1000500
There are 2 seals, one on each side of the bearing . You pack the bearings with grease. They don't run in the same oil as the diff.
ttotired
Posted 2019-06-05 4:17 PM (#582971 - in reply to #582943)
5000200010001001001002525
If your old ones had no grease, I would say your inner seals are no good
The grease will have been washed away by the oil
The oil would get there during cornering and being thrown around by the crown wheel ect
b5rt
Posted 2019-06-05 5:57 PM (#582979 - in reply to #582943)
2000100100100100252525
The inner seals are pretty easy to change, especially if you have the right tools. Harbor freight has them if you're on the cheap. A seal puller will get it out of there (it will be destroyed so make sure you have new seal in hand). A bearing race driver will push the new one in squarely. Don't try to over-push it as that will cause it to distort.
Posted 2019-06-06 7:53 AM (#583002 - in reply to #582943)
Subject: RE: Axle Bearing Question
2000100010010010010025
Alex, sealed bearings are the way to go. I recall I had difficulty in finding these here in Oz, but I cant recall the detail. I got my bearings from CBC.
Be aware that there is potential for a problem when mounting the bearings, I discovered this when doing my car. The problem is the radius on the inner race of the new bearings is bigger than the shoulder on the axles. The bearing ends up fitted against the shoulder too far onto the axle and makes a problem when setting up the axle end float. This is important to get right. I can give you more detail if you need it.
Steve.
ram300
Posted 2019-06-08 5:46 PM (#583125 - in reply to #582979)
10010010025
Anybody got a National/ CR or similar brand part number for that inner seal? I dont want confuse the parts boy with an old Chrysler number.
thanks
Alex
Posted 2019-06-09 12:56 AM (#583137 - in reply to #582943)
10010025
Sorry for not replying till now but have been away and only just returned.
Thankyou for your replies which have all been helpful.
Will keep in touch if I need more info.
Thanks.
Alex
Posted 2019-06-14 8:43 PM (#583462 - in reply to #582943)
10010025
Got a NOS 2.93 Crown and pinion for US $145. I have also had a drain plug fitted to the banjo housing and will place 3 small earth magnets in the housing, one at each end and one in the centre. Try to protect and preserve components as much as possible.
59 in Calif
Posted 2019-06-17 2:46 PM (#583584 - in reply to #582943)
Personally, I don't think much of the idea of putting a magnate inside that diff housing. A magnetic drain plug would be much better and should already be one there. If that magnet should happen to move around and get caught by the ring gear you can kiss it all goodbye !! Jerry
