Funnel?
Handygun
Posted 2019-05-20 7:57 AM (#582309)
Subject: Funnel?
What are you guys using to fill master cyl. with power brakes? I guess you check the level with your finger? Converted to disc brakes and gonna bleed one nite this week, so I've known this was coming, the only thig I can come up with is a funnel with a hose or a premix syringe with clear tubing. Am I missing something or is this setup this poorly thought out?
Old Ray
Posted 2019-05-20 9:41 AM (#582316 - in reply to #582309)
Subject: RE: Funnel?
500
Handygun - 2019-05-20 5:57 AM .... is this setup this poorly thought out?
Of course it is. I don't know, but what year model is your car, is the disc brake conversion aftermarket or OEM of a different year? Did you bench bleed the master cylinder, it helps a lot, that I do know .......... I forgot once.
ronbo97
Posted 2019-05-20 4:32 PM (#582332 - in reply to #582309)
2000200025
Funnel with flex hose at end. You can buy these at Pep Boys, etc. for a few dollars. Works great.
Ron
b5rt
Posted 2019-05-20 8:29 PM (#582341 - in reply to #582309)
Subject: Re: Funnel?
Lucas makes a fuel injector cleaner in a tall, slender, clear bottle. I use one of these bottles for refilling my master cylinder.
Posted 2019-05-20 8:43 PM (#582343 - in reply to #582309)
I attached a small kitchen funnel to a flexible drinking straw and it worked fine.
Stroller
Posted 2019-06-07 2:10 PM (#583072 - in reply to #582309)
1001001002525
Turkey baster and your finger.
