What part was that?
Direwolfe
Posted 2019-03-07 3:09 PM (#579003)
Subject: What part was that?
Looking to see if anyone has had the same experience.
I had the engine ( '61 Chrysler 413) rebuilt at the local shop. Before installing it I turned it over numerous times while working on it. I installed the torque converter with three "clunks" to register it to the trans. Installed block with heads into car. When I go to to rotate it for the first time I hear what sounds like a ring or circlip being forced out of a groove followed by the clattering of a part hitting a metal surface. Can't say for certain where noise came from, eg. engine lower end or tc, etc. although it sounded like it might have hit the oil pan.
Only real difference between previously turning over the engine and when part came off was engine now had tc and bell housing attached. Anyone have a similar experience?
Posted 2019-03-07 3:30 PM (#579004 - in reply to #579003)
Subject: Re: What part was that?
500050002000100025
Confused, the converter should be mounted to the crank shaft and the bell housing to the engine afterwards.
That is if the engine is a 61 with the cast iron hog A466
Posted 2019-03-07 5:06 PM (#579008 - in reply to #579003)
5000200020005001002525
The rod that drives the fuel pump can come out and fall down in there if you don't have a fuel pump installed on it.
