How to adjust brakes?
58Jackie
Posted 2019-02-17 2:34 AM (#578317)
Subject: How to adjust brakes?
Hey guys, I'd like to know how to go about adjusting the brakes on my 58 Belvedere. I need to back them off as they are halfway locked up. Where is the adjustment fastener located, do I need to take off the brake shoe? And when adjusting, is it the old rule of left=loose, right=tight?
Thanks guys.
BigBlockMopar
Posted 2019-02-17 4:02 AM (#578318 - in reply to #578317)
Subject: Re: How to adjust brakes?
20001000500252525
Make sure first the master brake cylinder isn't keeping them actuated.
You can crack open the bleeder for a second as a test to see if there's any pressure on the system.
Posted 2019-02-17 7:36 AM (#578319 - in reply to #578317)
500050002000100025
This is a good manual http://www.imperialclub.com/Repair/Lit/Master/125/index.htm there's also a film strip…...
