60 Imperial limousine
Moderators: ronbo97
   Forward Look Swap Meet -> For Sale - EBAY, CRAIGSLIST & OTHER FINDSMessage format
Posted 2019-02-06 7:15 AM (#577898)
Subject: 60 Imperial limousine
This one has been posted previous. Check out the chassis shots, unbelievable! Steve.
https://www.ebay.com/itm/1960-Chrysler-Imperial-Ghia-Limousine-Unres...
StillOutThere
Posted 2019-02-06 10:27 AM (#577899 - in reply to #577898)
Subject: Re: 60 Imperial limousine
2000100010010025
Presume you are referring to the added "boxing" component through the outsde center rails of the frame. The X-member was standard. The box sections served two purpuses. First of course the acted as reinforcing trusses to the main frame. Secondly, they added "bomb-proofing" as these are in fact medium gauge hollow steel boxes. If an explosive were detonated under the car, these boxes would take away some of the concussion by collapsing before the concussion would get to the outer floor sections and into the passenger compartment.
I didn't drive the '60 Ghia much that I owned but I can assure you I never felt any flex or heard so much as a rattle or squeak anywhere in the chassis.
Posted 2019-02-09 1:02 AM (#578001 - in reply to #577898)
Subject: RE: 60 Imperial limousine
Yes, bomb proofing is right!
looks like the main rails were cut and the chassis extended by a longer center piece. The X also looks extended.
Steve.
StillOutThere
Posted 2019-02-09 11:18 AM (#578005 - in reply to #577898)
2000100010010025
Recollection is the extension is 12.5 inches on the '60s.
(2011_01080016.JPG)
Attachments 2011_01080016.JPG (237KB - 89 downloads)
