56 Belvedere decode Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
dludvik76 |
Regular Posts: 52 | Hi all, Help decoding this vin? | ||
Expert 5K+ Posts: 9854 Location: Lower Mainland BC | dludvik76 - 2019-01-27 11:17 PM Hi all, Help decoding this vin? Straight up VINs do nothing for us (we can't help you). *IF* you have a photo of the cowl build tag, then more info is possible. The only way to get more info is to contact Fiat Chrysler Historical services in Detroit. | ||
dludvik76 |
Regular Posts: 52 | Can't get a picture to upload....trying again No bueno, here is a link to the tag: https://imgur.com/a/mMI99Ha Edited by dludvik76 2019-01-28 7:20 AM | ||
Expert 5K+ Posts: 9854 Location: Lower Mainland BC | dludvik76 - 2019-01-28 12:53 AM Can't get a picture to upload....trying again No bueno, here is a link to the tag: https://imgur.com/a/mMI99Ha The issue is your photo is >250 kB, the forum max. Here is is resized. What are the numbers under "SCHED"? 2208? Edited by 56D500boy 2019-01-28 8:15 AM (56PlymouthBuildTag_Small.jpg) Attachments ---------------- 56PlymouthBuildTag_Small.jpg (147KB - 179 downloads) | ||
dludvik76 |
Regular Posts: 52 | 2238. Thanks for the help | ||
Expert 5K+ Posts: 9604 Location: So. Cal | The only help that I can give you is that your car was built in Los Angeles. You can use the 508 trim code to get the right fabrics from SMS. Also, my '56 Savoy has the same M8=3, M9=8 on it that yours does. One of those is likely the 277 V8/automatic option since my car didn't come with many options like yours did. Edited by Powerflite 2019-01-28 9:57 AM | ||
Expert 5K+ Posts: 9854 Location: Lower Mainland BC | dludvik76 - 2019-01-28 9:28 AM 2238. Thanks for the help Hmm... Usually Sched = month/day like my LA built 56 Dodge is 0515, i.e May 15, 1956. Plymouth must be different. P29-3 = Belvedere (or Fury). Not exactly sure what the Paint code 671 is. I see 671 with a designation for both Eggshell white upper and Pine Green Lower. Here are the "raw" paint codes (with the combo lists, below) Here is the model designations (and VIN ranges): Edited by 56D500boy 2019-01-28 1:48 PM (55-56PlymouthModelDesignations.jpg) Attachments ---------------- 55-56PlymouthModelDesignations.jpg (126KB - 201 downloads) | ||
Expert 5K+ Posts: 9604 Location: So. Cal | Dave, that paint sheet tells you exactly what the 671 paint code is. It corresponds to an Eggshell White upper color and Pine Green Metallic lower color for a 2-tone car. | ||
dludvik76 |
Regular Posts: 52 | very helpful so far guys, thank you! | ||
Expert 5K+ Posts: 9604 Location: So. Cal | Please list all the options that you know your car came with. That may help us figure out what all the LA codes stand for in the future. | ||
dludvik76 |
Regular Posts: 52 | Right now, I only know it's a v8 auto car, AC, NO PS. I'm picking it up in a couple of weeks and doing some pre-research. You guys are correct, it is a white / pine green car as well. | ||
