1956 Custom Royal Powerflite
Gbreslin
Posted 2019-01-03 2:09 PM (#576203)
Subject: 1956 Custom Royal Powerflite
It has been suggested to me that the addition of an Overdrive unit to this transmission would improve mileage and lessen engine wear. Does this make sense to do?
Posted 2019-01-03 3:36 PM (#576208 - in reply to #576203)
Subject: RE: 1956 Custom Royal Powerflite
5000200020005001001001002525
Gbreslin - 2019-01-03 2:09 PM
George: That is a good theory but I think that in practical terms, it is not likely to be easy or cheap for a 56 Dodge Powerflite. There were overdrive units for the 56 Dodge 3 spd standard transmssions but based on the diagrams below, there are a lot of parts involved. I don't know if you could add an standard trans overdrive to the back of a Powerflite.
(56DodgeStandardTransmission_MainUnit.jpg)
(56DodgeStandardTransmission_OverdriveUnit.jpg)
Attachments 56DodgeStandardTransmission_MainUnit.jpg (153KB - 182 downloads)
Attachments 56DodgeStandardTransmission_OverdriveUnit.jpg (159KB - 191 downloads)
Posted 2019-01-04 2:55 PM (#576266 - in reply to #576203)
200010005001001002525
Adding an OD to the rear of a Powerflite is possible if you have access to lots of machine tools and an OD unit, not practical otherwise. Here's an OD conversion I did for a 727.
(TFR11lh.jpg)
(TFOTFR11 exp view01.jpg)
(TFR11lubelh.jpg)
Attachments TFR11lh.jpg (68KB - 181 downloads)
Attachments TFOTFR11 exp view01.jpg (69KB - 195 downloads)
Attachments TFR11lubelh.jpg (80KB - 194 downloads)
