Ethanol free gasoline
Moderators: Lancer Mike
   Forward Look Local Regions -> Rocky Mountain RegionMessage format
RICKYMOPAR
Posted 2018-12-07 8:43 AM (#574832)
Subject: Ethanol free gasoline
100100252525
I noticed more stations are now offering gasoline without ethanol. I have tested several the past month and found my trucks like it, especially mileage wise.
you can look some up on Pure gas. I tested 87 and 92 octane between different stations. I first noticed ethanol free fuel in Centennial's Murphy oil.
Have even tried Maverick's 87 octane. Federal Heights 88th at Pecos.
55BlueHeron
Posted 2018-12-07 9:51 AM (#574834 - in reply to #574832)
Subject: Re: Ethanol free gasoline
50025
I've been running ethanol free gas in both the blue heron and in the Mercedes. Both cars run better. I had problems with vapor lock in the Chrysler until I switched.
Posted 2018-12-07 10:00 AM (#574835 - in reply to #574832)
5000
yes ethanol is s**t, costs more to produce, uses a ton of water and pesticides, gets worse gas mileage and was basically a scam, govt paid out 50-60 billion in subsides.
With oil this cheap, even the govt is giving up this scam. I think the ethanol guys need to simply pay more to congress and buy those guys "vote".
Leadfoot1000
Posted 2018-12-08 1:30 PM (#574887 - in reply to #574832)
Subject: RE: Ethanol free gasoline
10010025
Hey 95 octane available 15 miles from my house according to Pure Gas, $100 for five gallons!
RICKYMOPAR
Posted 2018-12-10 6:25 PM (#575020 - in reply to #574832)
100100252525
Wow..the high cost of fuel there must suck. I can have racing fuel delivered to my shop at about one third of that cost.
Sonoramic60
Posted 2018-12-10 6:40 PM (#575021 - in reply to #574887)
1000100100252525
Lads --
In the event you're interested, Chief Petroleum in Colorado Springs has 110 Octane LEADED (!) racing fuel for $8.66 per gal. (+ sales tax, not fuel tax, e.g., about 6.5%). Since this is for off-road use only, you can't pump it directly in your tank, but rather into a separate container. Since Chief is also in Denver, I imagine it's available up there as well at about the same price, but I can't confirm it. I like to run about five gallons of this 110 leaded stuff in each tankful of my cars:
- '57 300C, 392 CID, 9:1 compression (but with hardened valve train) and 23 gal. tank
- '60 Fury, 383 CID, 10:1 compression (also with hardened valve train), 20 gal. tank
- '65 Vette, 327 CID, 11:1 compression (hardened valve train, but fuel injection system requires lead), 20 gal. tank
- '65 Sport Fury, 426 CID, 10.3:1, 25 gal. tank
So far, they all seem to do well on it, especially regarding plugs (and I'm knocking on wood as I write that).
Joe
RICKYMOPAR
Posted 2018-12-11 7:34 PM (#575077 - in reply to #574832)
100100252525
I was referring to finding fuel sans ethanol. and under $4. for premium under $3 for regular. It runs better, Yes I also doctored fuel when needed.
1961plymouthfury
Posted 2018-12-20 8:49 PM (#575577 - in reply to #575077)
200050010025
There is a website called pure gas . you can google it and it will tell you were you can purchase 100% gasoline
Stroller
Posted 2019-02-10 11:00 AM (#578037 - in reply to #574832)
1001001002525
I'd be happy to see all the gas pumps go back to clear view pumps. We don't get much of choice in what we have down here in the banana belt of colorado. I remember back in the in the mid '90's in vegas the Arco AM/PM's sold racing gas for $5.00 a gallon. It labeled 150 octane and had a blue dye color. Put a tank in my '77 Power Wagon w/440 and it loved it.
