413 Distributor 180 degrees out Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
1coolbanana |
Veteran Posts: 267 Location: Sydney | From the diagrams Im looking at, like the one below, my distributor appears 180 degrees out.
On my 413, #1 is where #6 is in the diagram above as is the lead of course. Does it matter? Its obviously been like this for many years, and someone inserted the tang 180 out and just rewired the leads, maybe been like that most of its life. TIA Edited by 1coolbanana 2018-11-07 9:48 PM | ||
Expert 5K+ Posts: 9901 Location: Lower Mainland BC | Looks like the firing order is still 1-8-4-3-6-5-7-2 which is what you want. Chizler once told me: 57chizler - 2017-06-09 2:32 PM Mopar has offered this decal for years; works on any engine with the 1-8-4-3-6-5-7-2 firing order. | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Yes, it's 180º out, but that doesn't really matter. 180º is better than any other "error" since the vacuum advance pot remains in the same position. Just leave it "as is" until you find a reason to pull the Dizzy. | ||
1coolbanana |
Veteran Posts: 267 Location: Sydney | Sounds like a good plan :-) | ||
chefothefuture |
Member Posts: 49 Location: Chuckanut Mountain, Washington | I'm having a similarly odd issue on my '61 361. The #1 wire is in the #4 position on the chart here. | ||
1coolbanana |
Veteran Posts: 267 Location: Sydney | chefothefuture - 2019-03-06 2:33 PM I'm having a similarly odd issue on my '61 361. The #1 wire is in the #4 position on the chart here. Do you have an aftermarket electronic distributor? I do now and my 1 is at #7 position which just so happens to be 180 from where you are! I could move the pump gear but Id rather leave it in the OEM position. Not sure if the 361 is the same as 413 though. Edited by 1coolbanana 2019-03-05 11:40 PM | ||
Mopar1 |
Expert Posts: 3033 Location: N.W. Fla. | As long as it is in proper order it doesn't matter where #1 is, unless it would confuse a mechanic who isn't paying attention. | ||
58coupe |
Expert Posts: 1740 Location: Alaska | I believe all the big blocks are timed the same. Just as Sven has said, 180 out is not a problem as long as you know this. About the other positions mentioned, I think the only way you can have these and still run right is someone put the gear that drives the distributor in wrong. I would probably also leave it as is until the engine has to be disassembled for some other reason. | ||
Expert Posts: 3776 Location: NorCal | If only the distributor is removed and installed 180 out, the error is symmetrical and the wire positions will be off 180 degrees but if the intermediate gear is also removed and installed incorrectly (for instance one tooth off) the wire positions will be asymmetrical. | ||
chefothefuture |
Member Posts: 49 Location: Chuckanut Mountain, Washington | 1coolbanana - 2019-03-05 11:38 PM chefothefuture - 2019-03-06 2:33 PM I'm having a similarly odd issue on my '61 361. The #1 wire is in the #4 position on the chart here. Do you have an aftermarket electronic distributor? I do now and my 1 is at #7 position which just so happens to be 180 from where you are! I could move the pump gear but Id rather leave it in the OEM position. Not sure if the 361 is the same as 413 though. No, my distributor is standard, but given the interesting quality of the work done on the engine by an earlier owner, I suspect something wonderful inside the block... I did re-insert the distributor with the shaft rotated 180 so the wires are now like the diagram. Pulling the heads off revealed something far far worse :-( Edited by chefothefuture 2019-03-30 12:09 AM | ||
