![]() Jump to page : 1 2 3 4 5 Now viewing page 5 [50 messages per page] | View previous thread :: View next thread |
Powerflite![]() |
Expert 5K+ Posts: 9430 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: So. Cal | The engine is coming together slowly. I'm not bolting down the intake because I like to visually check that the cam has good oil flowing over it before I crank it, just to verify for sure. Also, I will put a single 4bbl intake on it first for the cam break in, and after the motor is working well, then change over to the dual quads. I was thinking that I could use studs to hold the spacers to the heads, but obviously I can't use them on both sides. ![]() The 10:1 piston compression is reduced by 0.5 point by the thicker modern head gasket and increased by 1 point from the smaller 331 heads. So I expect to get around 10.5:1 out of this combo. I using an Isky 270 grind cam, the same grind I used in my '56 Savoy. I might be able to get away with a 280 grind due to the higher compression, but didn't want to take the chance on it. Edited by Powerflite 2022-03-27 3:37 AM (PG 57NY 392 hemi engine mostly assembled.jpg) Attachments ---------------- ![]() | ||
1960fury![]() |
Expert 5K+ Posts: 7288 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: northern germany | Looks great, but I wouldn't use that power robbing fan. | ||
Powerflite![]() |
Expert 5K+ Posts: 9430 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: So. Cal | I welded in a couple of rust holes in the rear window trough. There is another hole in the lower section at the far right of the picture that looks to have been there from the factory. It's where the two seams come together. I am considering leaving it, but not sure yet. It looks like I should reduce the size of the trim clip hole in at the far left of the picture as well. That elongated size is probably going to be a pain to seal well. I also welded in the small rust hole on the roof, from the roof trim and did a more thorough job fixing dents in the roof. I'm going to try to get the roof painted and the rear window installed. Edited by Powerflite 2022-06-26 10:56 AM (57NY PG Window Trough Welding.jpg) Attachments ---------------- ![]() | ||
Powerflite![]() |
Expert 5K+ Posts: 9430 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: So. Cal | I was just going to do a trial fit of the window to make any adjustments, if required. But then, I realized that my goal of getting the window installed was met, and I should move on to painting the firewall & installing the motor now. I am trying to get things put back together for a possible house move in the near future so my priorities are a skewed in that direction. The thought of moving the rear glass & motor to this car separately sounded like a bad nightmare. (57NY PG Rear Window.jpg) Attachments ---------------- ![]() | ||
Powerflite![]() |
Expert 5K+ Posts: 9430 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: So. Cal | As odd as it was to find that Danny's New Yorker 2dr coupe was built on the same day as this one, it's even more strange that the body tag on the radiator support of my copper/beige 2dr '57 Windsor was built on the same day as well! That's a Detroit style tag that doesn't belong to my Windsor as it also has an LA style tag on the firewall that does belong to it. It looks like the front end was swapped out on it at some point. Maybe it was originally a single headlight car, or maybe it got into a fender bender at some point in it's life? I wish I had more info on this car, other than it's front end and body tag, but that's all I have from it. And if that wasn't strange enough, lo and behold, the forest green 300C that recently came up for sale, was also built on the same day! Now I know of four 2dr Chrysler coupes, all built on the same day! What are the odds of that? (Copper 57 Windsor Front Tag-s.jpg) (79016751-770-0@2X.jpg) (1957_Chrysler_300C Body Tag.jpg) Attachments ---------------- ![]() ![]() ![]() | ||
57burb![]() |
Expert Posts: 3962 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: DFW, TX | That is so weird, man. They must have built them pretty well on that day! | ||
Powerflite![]() |
Expert 5K+ Posts: 9430 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: So. Cal | Maybe they saved them up to do at the same day? The hood on this car is from a '58 Chrysler with no badge on the front, the letters higher up, and also had a large, nasty dent in the front of it. Unfortunately, the dent was right over the under structure so I couldn't easily access the backside. I was contemplating cutting the inner structure out to get to it better, or drilling strategic holes into it, but finally I decided to try to get as far as I could without any cutting. That was a great decision as I was able to pop it out completely by hammering a very long & stiff body spoon that I inserted underneath the under structure. Worked perfectly. The paint on it isn't smooth enough to tell if it is completely done, but I can't feel any dents in it any more. I also took the time to lower the letter holes by 15/16" and drill the holes for the center badge. Now I need to weld in the old holes and clean them up. I noticed that the "S" emblem had been mounted upside down all these years (as seen by it's impression into the paint) as I had to turn it around to get them to all line up properly. ![]() Edited by Powerflite 2022-10-04 4:29 AM (P-G 57 New Yorker Hood Conversion.jpg) (Long Body Spoon.jpg) Attachments ---------------- ![]() ![]() | ||
Powerflite![]() |
Expert 5K+ Posts: 9430 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: So. Cal | The hood was covered with 7 layers of paint and bondo so I used a coarse 7" flapper disc to remove it all. I had to be careful because those can cut right through the metal quite easily. Now I could see that I need to work the bend a little more, but it's very close. I then put the back section of the hood together to re-weld the spots that had separated and massaged one corner back into it's proper shape. I'm thinking of sandblasting the hood now before painting the underside. I also got tired of the trunk lid looking like a '58. After drilling new holes for the '57 license plate bezel and welding up the '58 letter holes, I mounted the new bezel I obtained from BigM onto the car. (PG 57NY Trunk Welding.jpg) Attachments ---------------- ![]() | ||
Powerflite![]() |
Expert 5K+ Posts: 9430 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: So. Cal | I purchased another crossover that I cut to fit the 331 heads on this motor. I then tack welded the pieces together while bolted to the engine. I had to rotate the parts to ensure that I welded them at a middle point, not at one extreme. This time, I didn't bother to create one solid piece first before welding, but just put it together with 4 separate parts, which was a lot faster. I had about 1/16" gap all around them, and that seemed to work well to give me good weld penetration with the nickel wire. Now time to clean it up and it'll be ready to pressure test & paint. If it fails the test, I'll melt some brass over the failure area(s). It's funny to mount up this tiny spool of nickel wire to my welder because I usually run 12" spools on it. ![]() (392 Extended Crossover Welded.jpg) (Nickel Wire in Welder.jpg) Attachments ---------------- ![]() ![]() | ||
Powerflite![]() |
Expert 5K+ Posts: 9430 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: So. Cal | It came out pretty well. The nice thing is the extension area is mostly hidden by the generator when it's mounted on the engine. It will require a spacer in order to mount the generator on there. My pressure test didn't work out as well as I had hoped. I'll have to test it for real when I get the motor running. My last one didn't have any leak issues, so it should be fine. Now I need to cut out some gaskets so I can put these on for good. I have a lot of old gasket sets, but for some reason, I have very few of these water pump/crossover gaskets - maybe because it takes 4 of them per motor. Edited by Powerflite 2022-12-05 11:51 AM (392 Extended Crossover Finished.jpg) Attachments ---------------- ![]() | ||
Powerflite![]() |
Expert 5K+ Posts: 9430 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: So. Cal | The right front floor on this car isn't in very good shape. The left floor looks much better, and I'm hoping that it won't require as much work as this side. I cut the rusted section out to the size of my RCar replacement panel. After pounding out all the mis-placed impressions by RCar, I ended up with the body mount dimple in the wrong spot. It was also not quite as large as the originals, so I'm going to try again and weld it in when it's ready. I ended up just cutting off the long extension on the back outer part of the panel because it didn't line up very well either, and had a lot of pound marks from taking out the mis-placed seat mount. I also had to add in the raised square section in the back of it because they didn't bother to put it in. The floor is going to require some inner rocker & seat mount repair before I can weld the new floor in, but it's actually in better shape than my pink '56 Belvedere floor was, so that's good. I had to quit early today because of rain, so I didn't get as much done as I would have liked. I'll spend the rest of my day doing final assembly of the motor. Edited by Powerflite 2022-12-10 4:33 PM (PGreen 57NY Right Front Floor Rust.jpg) (PGreen 57NY Right Front Floor Cut.jpg) Attachments ---------------- ![]() ![]() | ||
Powerflite![]() |
Expert 5K+ Posts: 9430 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: So. Cal | I was questioning why I kept the floor from the Forest Green '57 New Yorker 4dr hardtop around. The rockers on it were in terrible shape and there was significant rust under the heavy metal platform used for the rear door post (I have already removed it before taking this picture). But amazingly, the top of the front rocker was actually in decent shape so I can use it to fix the top of my coupe's rocker. That saves me from having to make that from scratch as no one makes the inner top section. Even though the rear floor has a terrible rust hole from the metal platform that sat on top of it, the rest of the rear floor is in great shape too, along with the pockets above them. So I am planning to use that area as well. The moral of the story is to never throw anything away! ![]() (57NY 4dr Hardtop Passenger Floor.jpg) Attachments ---------------- ![]() | ||
22mafeja![]() |
Extreme Veteran Posts: 583 ![]() ![]() ![]() ![]() Location: Finland | Those pictures make my hands itch..so much interesting and rewarding work to enjoy..lucky you Nathan... | ||
Powerflite![]() |
Expert 5K+ Posts: 9430 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: So. Cal | This car has plenty of rust repair for you to satisfy your itch once you finish your car, Ralf. You are more than welcome to come over and try your hand on these. ![]() (57NY Passenger Floor Cut.jpg) Attachments ---------------- ![]() | ||
22mafeja![]() |
Extreme Veteran Posts: 583 ![]() ![]() ![]() ![]() Location: Finland | I might consider this interesting offer next time the temperature drops below -20 degrees....I could work for food and shelter... Don`t be afraid...just joking.. Edited by 22mafeja 2022-12-24 3:32 AM | ||
Powerflite![]() |
Expert 5K+ Posts: 9430 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: So. Cal | ![]() (PGreen 57NY Patched Panels.jpg) Attachments ---------------- ![]() | ||
Powerflite![]() |
Expert 5K+ Posts: 9430 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: So. Cal | All the rain has delayed my progress quite a bit on this project. I may have to interrupt it to work on other things if I don't get a lot done on it tomorrow. Right now I am making the inner rocker patch panels and thought I would show my poor man's sheet metal brake. It isn't fancy, but it get's the job done. ![]() (Poor Man's Sheet Metal Brake.jpg) Attachments ---------------- ![]() | ||
22mafeja![]() |
Extreme Veteran Posts: 583 ![]() ![]() ![]() ![]() Location: Finland | That`s the right spirit Nathan , fancy tools are not needed really if one is resiliant. Low tech rules ![]() | ||
Powerflite![]() |
Expert 5K+ Posts: 9430 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: So. Cal | Maybe someday I can see if their claim holds true. I made this picture both from the '57 and '58 Chrysler manuals. (57 Chrysler Off Good Start.jpg) Attachments ---------------- ![]() | ||
Powerflite![]() |
Expert 5K+ Posts: 9430 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: So. Cal | I made some progress on the floors in this car. I finished the inner rocker repairs and cleaned up the front section enough to be able to place and spot weld the new plan into place. I didn't drill out the plug weld holes in the panel yet. I am thinking of trying to do that after it's placed down, using a carbide cutter to make the holes. If that fails, I'll pull the panel back out and drill them first. I'm happy to have my first home-made body pocket installed in this panel. Hopefully, I can make them even better and quicker on all the future projects. I need to get working on the Fireflite again, so I will likely put this project aside for awhile. I was hoping to get it done before now, but life got in the way and I didn't get as much done as I had hoped. (PGreen 57NY Rt Floor Pan Tacked.jpg) Attachments ---------------- ![]() | ||
