Opening stuck doors?
Apollo 61
Posted 2018-10-22 12:48 AM (#572143)
Subject: Opening stuck doors?
5001001002525
I have a few cars that I picked up that have been sitting for awhile. The doors are unlocked but just won't open. I've tried WD 40 and trying both inside and outside handles at the same time. Light prying while doing that. Still stuck. Any suggestions?
Posted 2018-10-22 9:14 AM (#572159 - in reply to #572143)
Subject: Re: Opening stuck doors?
5000
neither door will work? thats weird... is the car rusty? spray some liquid wrench all down the back of the door inside I guess.
61yorker
Posted 2018-10-22 12:15 PM (#572170 - in reply to #572143)
New User
The latches are frozen, your either going to have to pull the seat and the door panels or try and get lucky and spray from the window channel towards the back of the door lock. Good luck and be patient.
Apollo 61
Posted 2018-10-22 1:29 PM (#572174 - in reply to #572143)
Subject: RE: Opening stuck doors?
5001001002525
I have 4 65'66 4dr imperials that all seem to have 3 doors that that are not opening. I guess I will have to remove the front seat,then remove back , then remove panels , then do a little hammering on latch?
60 dart
Posted 2018-10-22 4:49 PM (#572184 - in reply to #572143)
50002000100050010010010010025
might be what some would call a really stupid question but being all your cars have the same problem , are you sure to mechanism is really unlocked -----------------------------------------later
