honing cylinders with gunk penetrating oil
60 dart
Posted 2018-10-10 11:51 PM (#571474)
Subject: honing cylinders with gunk penetrating oil
50002000100050010010010010025
should never be done and i learned the hard way. i use to use 30 weight oil but thought i'd be a smart ass and use the little penetrating gunk i had left . what a huge
mistake . won't come off with a rag or brushing but did after over an hour with my pressure washer and after i hit every square MM . simply disgusted i am with myself ---------------------------------later
Posted 2018-10-11 12:16 AM (#571479 - in reply to #571474)
Subject: Re: honing cylinders with gunk penetrating oil
500050002000100025
Alcohol cleans out very well. I use 92% alcohol for to clean out wheel cylinders after honing.
60 dart
Posted 2018-10-11 3:24 PM (#571522 - in reply to #571474)
wiz , i use 90% and it wouldn't touch it . i even used wheel cleaner but no go , power washing was the only alternative i had left----------------------------------------------------------later
Stroller
Posted 2018-10-26 1:28 PM (#572408 - in reply to #571474)
1001001002525
CRC red can brake cleaner nough said.
