Location: Michigan | Can some one help me get started polishing S S. Do I have to do all three wheels
course, medium and fine ? I have no scratches just a dull finish on SS
Thank Alex
Location: Newark, Texas (Fort Worth) | Start with the fine first. You will know in less than a minute if it needs more 'grit'. |
Location: Muskego, WI | Send me your email address. I have a pdf document from Eastwood, I bought their buffing starter kit and I've been able to produce good results following their instructions.
Edited by jboymechanic 2018-10-04 1:39 PM
Thank both of you
Alex |
| Hm little trick I learned regarding cleaning up stainless is quite easy. Aluminum foil and water. Just kinda wad up a piece of foil, dip in water and polish. Use a clean cloth to buff out and you will be surprised. |
