1957 D 500 2 carb
   Forward Look Technical Discussions -> Fender/VIN Tag and Broadcast Sheet DecodingMessage format
57RID500
Posted 2018-09-25 2:35 PM (#570755)
Subject: 1957 D 500 2 carb
On a 1957 D 500 2 four barrel carb set up
Is there a specific engine code for the 2 four barrel car?
Did they have an Offenhauser intake or dodge intake?
what brand carb did they have and numbers on carb?
thanks as always for the help
Bob
Posted 2018-09-25 3:56 PM (#570761 - in reply to #570755)
Subject: RE: 1957 D 500 2 carb
I am not going to even pretend to know the answer other than we have gone around (and around) on this before with no conclusions.
The Intake manifold PNs are somewhere in here:
The carburetors will be Carter WCFBs. One of them might be a 2622S but I don't know. My 56 D500 single 4 bbl carb was a 2443S. The 58 D500 was a 2642S and the 57 D500 shows as a 2622S. Here is the list:
Edited by 56D500boy 2018-09-25 3:59 PM
(56-58D500CarbNumbers.jpg)
Attachments 56-58D500CarbNumbers.jpg (170KB - 242 downloads)
arizona mopar gold
Posted 2018-09-25 4:52 PM (#570763 - in reply to #570755)
Subject: Re: 1957 D 500 2 carb
500
What are the numbers on your data tag under BDY?
Posted 2018-09-25 5:46 PM (#570769 - in reply to #570761)
57 D500 Engine info (including mention of the 2 x 4 bbl option):
57RID500
Posted 2018-09-26 8:23 AM (#570781 - in reply to #570755)
thsi is the IBM card
(dual carb d 500.jpg)
Attachments dual carb d 500.jpg (228KB - 234 downloads)
Attachments dual carb d 500.jpg (228KB - 223 downloads)
LD3 Greg
Posted 2018-09-26 11:05 AM (#570785 - in reply to #570781)
Hi Bob,
As you and I previously discussed, I believe this is a righteous Super D. Do you have a renewed interest in it? If so there are a number of things I would like to discuss.
Greg
Posted 2018-09-26 11:21 AM (#570786 - in reply to #570781)
57RID500 - 2018-09-26 8:23 AM
this is the IBM card
Hmm...you sure? I know I posted that IBM card before and it was a regular single 4 bbl D500.
LD3 Greg
Posted 2018-09-26 11:48 AM (#570789 - in reply to #570786)
A regular D 500 would be coded and punched for code 372. Clearly this car isn't.
Greg
57RID500
Posted 2018-09-26 5:34 PM (#570800 - in reply to #570755)
so
Gregg, so what do you think this car is? a dual 4 barrel? not a regular single four barrel? thankS AGAIN Bob
LD3 Greg
Posted 2018-09-27 11:11 PM (#570845 - in reply to #570800)
This cars card is coded and punched for sales code 491 which is Super D 500. Please post pics of the car so we can get on with the factory details that will separate it from clones. The mechanical equipment needs to be accurate!!
Greg
Posted 2018-09-28 1:05 AM (#570850 - in reply to #570845)
LD3 Greg - 2018-09-26 11:48 AM
Greg
LD3 Greg - 2018-09-27 11:11 PM
Greg
Greg: I assume that your comments are based on the info sheet that you and D500Neil created while he was still alive?
This?
(NeilAndGregsBuildSheetCheatSheet_larger.jpg)
Attachments NeilAndGregsBuildSheetCheatSheet_larger.jpg (161KB - 240 downloads)
LD3 Greg
Posted 2018-09-28 8:00 AM (#570859 - in reply to #570850)
It is just a readable copy based on the real thing.
Like this.
Greg
LD3 Greg
Posted 2018-09-28 8:03 AM (#570860 - in reply to #570859)
Like this?
(image.jpg)
Attachments image.jpg (229KB - 235 downloads)
LD3 Greg
Posted 2018-09-30 7:12 PM (#570977 - in reply to #570850)
56D500boy - 2018-09-28 1:05 AM
Greg
Greg
This?
Here is a broadcast sheet for a 57 CRL 2Dr HT D 500 for your collection. Nice car!
BTW, these broadcast sheets list all the actual sales codes.
Greg
(image.jpg)
Attachments image.jpg (212KB - 232 downloads)
LD3 Greg
Posted 2018-09-30 7:22 PM (#570978 - in reply to #570977)
That is Neils handwriting at the bottom wondering why they are calling a charcoal met car black! He later determined that the note meant a black dash panel and a matching dash pad if ordered.
Greg
Posted 2018-09-30 9:32 PM (#570985 - in reply to #570977)
Greg: Thanks for posting that copy of an original 57 (or 58?) broadcast sheet.
Any idea whether the same or similar exists for the 56 Dodges? I've looked for mine (under the seats, under the carpet, on top of the glove box) but nothing has shown up.
Anybody?
LD3 Greg
Posted 2018-09-30 9:45 PM (#570987 - in reply to #570985)
It is 57 only and I have no info for 56 at all.
Greg
Posted 2018-09-30 9:58 PM (#570988 - in reply to #570987)
LD3 Greg - 2018-09-30 9:45 PM
Greg
I've posted a APB for a 56 Dodge Broadcast sheet in the wanted section.
LD3 Greg
Posted 2018-10-01 11:15 PM (#571038 - in reply to #570988)
56D500boy - 2018-09-30 9:58 PM
Greg
I am just asking, but, are you sure Dodge in 56 used broadcast sheets? In 57/58 I'm unsure whether or not Plymouth, Chrysler or Imperial even used broadcast sheets!?
As I understand it, broadcast sheets were just "checklists" for the various assembly/subassembly areas to be sure cars were built as ordered. Required because these Dodges had many and many different options! A crazy number actually!!
We have seriously hijacked this thread!
Greg
