Location: McComb, Mississippi | Does anyone know how thick the jute padding was on Imperials? I've asked on other sites and never got an answer. I see various thicknesses for sale and I'm trying to make this car as quiet as possible. Thanks |
Location: North Australia | G'day Christian, in my 60 Imp the original under carpet padding was approx 1/2 inch thick!. When I replaced the carpet (with the heavy duty backing), I used a layer of 8 mm closed cell foam with foil, and a layer of similar style under carpet Jute, and then the heavy duty carpet. It all fit pretty good, and I think is approx 3/4 inch thick overall. My Car is extremely quiet!
Steve. |
Location: Lower Mainland BC | plymouth - 2018-09-20 1:32 PM
Not saying that you should follow my example but before I put my new carpet down with the "synthetic jute" (polyester or something) backing, I applied Dynamat, Eastwood X-mat (thin) and Eastwood X-mat (thick) on my next to perfect bare floors. I am very happy with the results.
During the process:
REFERENCE: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=67310&...
Location: McComb, Mississippi | So far I have coated the floor with por-15, put down two layers of Fatmat and temporarily put down the carpet. The car is pretty darn quiet, but I want to add the Jute padding. Thanks for the comments. |
Location: Lower Mainland BC | plymouth - 2018-09-23 10:34 AM
If your carpet doesn't have a insulation backing or even if it does, you might want to check out this from Stock Interiors (it's modern, non-biodegradable "jute"):
https://www.stockinteriors.com/jute.asp?ItemId=4794
Edited by 56D500boy 2018-09-23 12:07 PM
Location: Frederick, MD | I know this thread has been dormant for a couple of months and you've almost certainly finished with your carpet installation. However, I would like to add that I have been very satisfied with the upholstery supplies I have purchased from yourautotrim.com, including carpet padding. |
Location: McComb, Mississippi | I was actually about to update this. I finished the floor. Now, I am looking for something to insulate the firewall with. It's been treated with por-15 and fatmat. Any ideas? |
