L-350 identification needed
Mackey58
Posted 2018-09-02 8:11 AM (#569413)
Subject: L-350 identification needed
Hello, I have two engines both stamped L-350 under this one is stamped 53706 the other 42562 . What do these second set of #s indicate. What do have I have here? One is supposed to be original out of my 58 belvedere. The other is supposedly out of a 58 cop car. Also I have a single four intake casting # 2205968 Thanks
springsweptwing
Posted 2018-09-02 10:56 AM (#569420 - in reply to #569413)
Subject: RE: L-350 identification needed
100010025
Second set of numbers is the engine number, you might find it stamped on you're frame near rear spring hanger on left hand side, or confirm on your build sheet?
Mackey58
Posted 2018-09-02 3:01 PM (#569444 - in reply to #569413)
Subject: Re: L-350 identification needed
I will look at the frame thanks
