318 Thermostat Housing Question
GaryS
Posted 2018-08-26 12:49 PM (#569048)
Subject: 318 Thermostat Housing Question
1000100100
The thermostat housing on the ’66 Poly 318 I’m installing in my ’56 Plymouth breaks out at an angle toward the side of the engine, but I need one the either points forward, or straight up to clear the aftermarket AC. I suppose I could make a flex hose work, but I really hate them if there is a way to avoid it.
I’ve seen older Poly and Hemi engines that point up, but I’m not sure if the dimensions are correct for my application.
I need 1-1/2" hose fitting and 3-1/4” mounting hole spacing, but so far I haven’t been able to find an aftermarket part, or later stock Mopar part that will work for me. Does anyone have a suggestion where to find something that would fit?
Posted 2018-08-26 2:11 PM (#569054 - in reply to #569048)
Subject: RE: 318 Thermostat Housing Question
5000200020005001001001002525
I too am looking for an aftermarket (or NOS OE) thermostat housing for my 56 Dodge. In the interim, I bought a used housing and had a muffler shop bend, swage and weld an appropriate piece of pipe on to match the rusty bits that were removed. That might be an option for you.
Here are some photos. Still needs to be cleaned up and painted (not installed yet).
Edited by 56D500boy 2018-08-26 2:14 PM
(MufflerShopAttemptAtCreatingANew56DodgeV8ThermostatHousing_1.jpg)
(MufflerShopAttemptAtCreatingANew56DodgeV8ThermostatHousing_2.jpg)
(MufflerShopAttemptAtCreatingANew56DodgeV8ThermostatHousing_3.jpg)
(MufflerShopAttemptAtCreatingANew56DodgeV8ThermostatHousing_4.jpg)
Attachments MufflerShopAttemptAtCreatingANew56DodgeV8ThermostatHousing_1.jpg (65KB - 481 downloads)
Attachments MufflerShopAttemptAtCreatingANew56DodgeV8ThermostatHousing_2.jpg (58KB - 462 downloads)
Attachments MufflerShopAttemptAtCreatingANew56DodgeV8ThermostatHousing_3.jpg (66KB - 480 downloads)
Attachments MufflerShopAttemptAtCreatingANew56DodgeV8ThermostatHousing_4.jpg (72KB - 484 downloads)
Posted 2018-08-26 3:58 PM (#569058 - in reply to #569048)
200010005001001002525
Both of these are factory stock 1 1/2" nipples with 3 1/4" bolt spacing.
(T-Stat.JPG)
Attachments T-Stat.JPG (140KB - 491 downloads)
GaryS
Posted 2018-08-26 5:02 PM (#569060 - in reply to #569048)
Subject: Re: 318 Thermostat Housing Question
1000100100
Any part numbers stamped on those?...or do you know which engine they came from? The only ones I could find in stock at three local auto parts stores all had 1-1/4" nipples or the wrong bolt spacing.
I also considered the exhaust pipe idea, but years ago I had a similar setup blow the hose off without a shoulder to retain it, so I was hesitant to try it again.
Posted 2018-08-26 6:08 PM (#569062 - in reply to #569060)
GaryS - 2018-08-26 5:02 PM
I think those came from flat-head sixes. While searching for examples, I found this:
https://www.ebay.ca/itm/Chrome-Water-Neck-Thermostat-Housing-Dodge-C...
GaryS
Posted 2018-08-26 7:40 PM (#569064 - in reply to #569048)
1000100100
Wow! I wonder how I missed that one when I searched e-bay. It looks like the one I need and the price is right. Thanks!
Posted 2018-08-26 8:49 PM (#569068 - in reply to #569048)
50001000100100100100252525
https://www.ebay.com/itm/NOS-MOPAR-1957-9-PLYMOUTH-DODGE-6-1958-DESO...
/382509033769?epid=1328482788&hash=item590f50a929:g:XOcAAOxykMpTIyCv&vxp=mtr
