oil filter
TERENCE
Posted 2018-08-08 4:49 AM (#568048)
Subject: oil filter
hello anybody can advice about oil filter options for 318 poly ...original filter is a purolator p75 -1 so looking for a common found replacement if any one can help ...good on ya...
Posted 2018-08-08 6:20 AM (#568053 - in reply to #568048)
Subject: Re: oil filter
50001000100100100100252525
https://www.google.com/search?client=firefox-b-1&biw=979&bih=432&tbm...
q=oil+filter+301++plymouth&oq=oil+filter+301++plymouth&gs_l=psy-ab.3...11367.11367.0.11704.1.1.0.0.0.0.52.52.1.1.0....0...1c.1.64.psy-ab..0.0.0....0.h
.0.52.52.1.1.0....0...1c.1.64.psy-ab..0.0.0....0.hDEYLjOHPbA
https://brillman.com/product/b9024-003-oil-filter/?gclid=EAIaIQobChM...
Edited by mstrug 2018-08-08 6:23 AM
Posted 2018-08-08 6:22 AM (#568054 - in reply to #568048)
https://www.ebay.com/i/372134368153?rt=nc&_trkparms=aid%3D222007%26a...
0160908110712%26meid%3D2f902616c0ed44c88c3e10513fb28065%26pid%3D100677%26rk%3D1%26rkt%3D3%26sd%3D312001621420%26itm%3D372134368153
Posted 2018-08-08 5:39 PM (#568079 - in reply to #568048)
50002000200050010025
You can get the original filters at NAPA too, a real parts store. I *beleive* that the fitting for the oil filter housing is the same as the early hemi's. If so, you should be able to adapt it to a spin-0n type of filter using an adapter from HotHemiHeads.com. If you call him, he will usually know if it will fit or not.
Mopar1
Posted 2018-08-08 8:19 PM (#568093 - in reply to #568079)
2000100025
Powerflite - 2018-08-08 4:39 PM
My understanding is an LA oil filter set up will bolt right on if you remove the OEM base.
TERENCE
Posted 2018-08-12 5:15 PM (#568313 - in reply to #568048)
Subject: RE: oil filter
Hi ...thanks for your advice and leads fella's really helpful ...
cheers
Tc
