Gaskets and grommets
G8WAY-Z
Posted 2018-06-18 10:21 PM (#565309)
Subject: Gaskets and grommets
New User
I need to replace the rubber gaskets and grommets that prevent air from seeping into the cabin from the firewall i.e. wiring harness grommet, clutch pedal gasket, steering wheel column gasket, etc. Where can these be sourced?
Posted 2018-06-19 10:45 AM (#565323 - in reply to #565309)
Subject: RE: Gaskets and grommets
200010005001001002525
http://www.garygoers.com/cat10toc.pdf
Supplies of some items may be limited due to the owner's medical problems.
G8WAY-Z
Posted 2018-06-19 9:27 PM (#565342 - in reply to #565323)
New User
Thanks. Found many of the parts I need. Hope they're still available!
Posted 2018-06-20 12:54 AM (#565351 - in reply to #565309)
Subject: Re: Gaskets and grommets
5000
i sent emails and i get nothing back. Maybe just do the faxing. Update this thread if you get a response.
christine-lover
Posted 2018-06-20 12:39 PM (#565370 - in reply to #565351)
2000500100100100100252525
I sent an order in a few weeks back, check hasn’t been cashed yet. I heard he still had some items in stock, but not making new rubber parts.
