power seat 57 New Yorker Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
billy |
Extreme Veteran Posts: 395 Location: upstate new york | Hey Forward Lookers, Is there only 8 nuts bolting the front seat to the floor? I don't have a lift, so what i can see is 4 studs and nuts coming thru the floor on each side...Are there more in the center of the car? Thanks folks, billy | ||
57burb |
Expert Posts: 3967 Location: DFW, TX | You got it. That's all that holds it in. | ||
billy |
Extreme Veteran Posts: 395 Location: upstate new york | Thanks Danny | ||
billy |
Extreme Veteran Posts: 395 Location: upstate new york | So. I'm messing with the power seat today, cleaning out years of junk from under the seat and blowing out the deteriorating seat dust and spraying the track and racks to try and get it freed up. Got some movement up, down and tilt....does not want to go forward and backward. Then after awhile of pushing the power buttons, a faint puff of smoke came out of the switch and now only 2 of the 3 buttons are groaning/working....since we do not have fuses as far as I know, does this mean I fried the switch? Can it be repaired? Any help would be appreciated. My plan was to pull the seat and get it reupholstered this winter , but now the seat is too far forward for my fat ass to fit in it. I can get in but its tight...help guys,,,how do I fix this? BILLY | ||
Expert 5K+ Posts: 9648 Location: So. Cal | You need to gather up all that smoke and put it back into the switch. These switches are very repairable. You probably melted or burnt a connection. Take the switch apart and clean it up to see what you have. A guy in Canada makes some really nice replacement switches that I highly recommend to avoid the ancient cardboard that these are made from. He sells them on ebay, but (just a warning) they aren't cheap. But once you get it working, don't just force the motor to push against the hard stoppages. You need to take the tracks apart and really clean & lube them before you start applying power to the motor. Edited by Powerflite 2018-07-06 9:05 PM | ||
billy |
Extreme Veteran Posts: 395 Location: upstate new york | Nathan, Do you have a name of the Canadian guy? I did a quick search and could not find. Safe to say the best way to dis=assemble and clean up is to remove the seat from the car? Wish i could put the smoke back.....:) Thanks, billy | ||
Expert 5K+ Posts: 9648 Location: So. Cal | I believe it was camer.mikov, but it has been too long now so I don't remember. I don't see any for sale now. Definitely remove the seat and the tracks to get them working properly. | ||
billy |
Extreme Veteran Posts: 395 Location: upstate new york | Weii, i took it apart and as you can see by picture, i"ve definitely smoked part of it...looks fairly easy to repair although the spring mechanisms can be a chore to align... (IMG_2978a.jpg) Attachments ---------------- IMG_2978a.jpg (35KB - 138 downloads) | ||
ronbo97 |
Expert Posts: 4036 Location: Connecticut | The main feed to the power seat should be going thru a circuit breaker behind the kick panel on the driver's side. That's to prevent damage to the motor and switch. You should not try to force the seat. If it's binding, remove the seat from the power assembly and clean thoroughly. Then test the assembly. Ron | ||
billy |
Extreme Veteran Posts: 395 Location: upstate new york | Thanks for the advice Ron....know anyone who repairs the circuit boards? billy | ||
ronbo97 |
Expert Posts: 4036 Location: Connecticut | billy - 2018-07-10 1:22 PM Thanks for the advice Ron....know anyone who repairs the circuit boards? billy Circuit boards ? It's a six-way switch. No circuit boards involved, IIRC. Ron | ||
miquelonbrad |
Expert Posts: 1737 Location: Hay Lakes, Alberta, Canada | You could bridge the gaps with solder braid...it's copper, and wide/flat like the "trace". The switch may look like a circuit board a bit, but the reality is that the repair needs to be heavier than the thin, glue-on repair kits that are used to repair modern circuit boards. | ||
springsweptwing |
Elite Veteran Posts: 1141 Location: Blackpool, United Kingdom. | Powerflite - 2018-07-07 2:56 PM I believe it was camer.mikov, but it has been too long now so I don't remember. I don't see any for sale now. Definitely remove the seat and the tracks to get them working properly. https://www.ebay.com/str/This-Old-Warehouse/DeSoto-1955-1960-/_i.htm... | ||
billy |
Extreme Veteran Posts: 395 Location: upstate new york | Hey peeps, if you've read this far, you know i burned up part of my switch...are there any manual adjustments that can be made with no power to a switch? I need to move it back a bit or lose alot of weight:) thanks, billy | ||
dlyle |
Veteran Posts: 236 Location: Morgan Hill, CA | You can hook the wires together if you have no switch. Here's the skinny: (Page20.jpg) Attachments ---------------- Page20.jpg (90KB - 154 downloads) | ||
dlyle |
Veteran Posts: 236 Location: Morgan Hill, CA | Here are some links that might be helpful too. The first one contains the seat wiring diagram from above. http://www.imperialclub.org/Repair/Lit/Master/134/Page14.htm http://www.imperialclub.org/Repair/Lit/Films/134/index.html | ||
billy |
Extreme Veteran Posts: 395 Location: upstate new york | Doug, Thank you so much for the information...will definitely help in my troubleshooting my seat...that is exactly what I've been looking for... billy | ||
dlyle |
Veteran Posts: 236 Location: Morgan Hill, CA | billy - 2018-07-17 5:55 AM Doug, Thank you so much for the information...will definitely help in my troubleshooting my seat...that is exactly what I've been looking for... billy You're welcome. I had the seat out of the car and had a 12 volt battery to test it. I cleaned it up and lubed it then operated it in all directions to bring it back to life. Once I did that I hooked up the switch and it all worked. Put it back in and all is well but am getting a little shock when I operate the switch. Investigating that now. | ||
billy |
Extreme Veteran Posts: 395 Location: upstate new york | Did you bolt it down somehow while servicing it? billy | ||
ColoradoFiredome |
Veteran Posts: 111 Location: Aurora, Co | I have the front bucket power seats out of a 73 New Yorker convertible. I have a similar issue. As I'm about to have the interior done, it appears that the seat will have to be removed from the power framework. That bugger weighs a ton. Nearly gave myself a hernia getting it in. My plan involves removing the seat from the power frame so the upholstery guy can cover it. Mine only has 4 studs per seat & a little metal massage was required to get the passenger side to sit flat on the floor. I plan to investigate the switches as mine will not tilt down in the back. Thanks for the wiring diagram. I'm sure it will come in handy. Later. | ||
dlyle |
Veteran Posts: 236 Location: Morgan Hill, CA | billy - 2018-07-31 8:42 AM Did you bolt it down somehow while servicing it? billy I did not. Just had it on the garage floor. | ||
billy |
Extreme Veteran Posts: 395 Location: upstate new york | So i have the interior out of my 57 New Yorker...driving it around sitting on a milk crate currently...I have the power seat mechanism out and i have the schematics to connect wires and get it to move some...some directions work, some do not...it looks like some of it is rusted together...whats the next step in getting this thing apart so i can clean it all up and get it working again??? I have the whole thing out and on a table, but not sure how it comes apart...anyone have power seat disassembly instructions? Thanks billy (power seat.jpg) Attachments ---------------- power seat.jpg (151KB - 116 downloads) | ||
billy |
Extreme Veteran Posts: 395 Location: upstate new york | Have 1 side apart now....should the lower steel base parts slide within each other? Not sure if this is how the forward and backward work...mine seems to be rusted together,,,,should these slide free? (power seat apart2.jpg) Attachments ---------------- power seat apart2.jpg (105KB - 117 downloads) | ||
miquelonbrad |
Expert Posts: 1737 Location: Hay Lakes, Alberta, Canada | Here is a blow up, from the '59 shop manual... Edited by miquelonbrad 2018-09-27 9:49 PM (IMG_0199.JPG) Attachments ---------------- IMG_0199.JPG (178KB - 115 downloads) | ||
Expert 5K+ Posts: 9648 Location: So. Cal | Could you email me a bigger version of that file? Thanks. | ||
Expert 5K+ Posts: 5006 | download from mymopar | ||
billy |
Extreme Veteran Posts: 395 Location: upstate new york | Thanks for the picture Brad... | ||
rebel |
Extreme Veteran Posts: 309 Location: Western Colorado | Billy, Yes it should slide back and forth. There is a thin wear piece that is riveted to the top side of the lower track that rusts into pieces and will seize the tracks. I rebuilt one for a friend and ended up using a piece of bandsaw blade to replicate that thin wear strip. If I remember correctly, I had to remove at least two of the studs to slide the upper and lower pieces apart. Make sure the entire unit is either back in the car or bolted/attached evenly to a piece of plywood before running it back and forth. It is VERY easy to break the pot metal housings that house the gear tracks. Don't ask how I know!! Good Luck! Bob | ||
billy |
Extreme Veteran Posts: 395 Location: upstate new york | Thanks Bob...good info...i'll keep a look out for that wear strip if i ever get it apart.... billy | ||
