1960 Plymouth Voltage Reducers for Gages
rpantaleo1960
Posted 2018-05-20 8:12 PM (#563718)
Subject: 1960 Plymouth Voltage Reducers for Gages
Looking for guidance on finding replacement, or rebuilding kits for voltage reducers for the gas and temperature gages.
Thanks,
Robert
ttotired
Posted 2018-05-20 9:49 PM (#563727 - in reply to #563718)
Subject: Re: 1960 Plymouth Voltage Reducers for Gages
50002000100010010010010025
Search this site using the search function
User "Wizard" has a good fix using electronic components to make a new one
Posted 2018-05-22 11:10 AM (#563826 - in reply to #563718)
Subject: RE: 1960 Plymouth Voltage Reducers for Gages
20001000500100100252525
http://www.moparts.org/Tech/Archive/elec/11.html
Posted 2018-05-31 5:08 AM (#564291 - in reply to #563718)
Or this.
http://rt-eng.com/rte/index.php/RTE_limiter
lozrox58
Posted 2018-06-05 5:24 PM (#564625 - in reply to #563718)
eBay is your friend. There are hundreds of 12volt to 6volt, or 12volt to 5 volt regulators all for less than $4 delivered to your door. These are all sealed and water proof. Most will supply 3 amps which is ample for your needs. Or there are more expensive models which can provide more current.
