1958 350 Golden Commando oil question
58Belvedere
Posted 2018-05-12 7:38 AM (#563222)
Subject: 1958 350 Golden Commando oil question
100252525
Hi all!
I know oil is a hot button topic and I've read a lot of threads on it. I've been using Mobil1 synthetic in my '58 Plymouth 350 since about 2003, but I'm not sure if that's the best for it
Hemmings is selling oil with high zinc (but they don't tell the level) https://www.hemmings.com/store/detail?product_id=1810
Is that the right way to go? Mobil1 has 900ppm of zinc...is that not sufficient? It certainly is cheaper than what Hemmings is offering.
10w30 is the weight I've used in the past, does that make sense to keep with?
I also just use the same oil filters that fit on a 383, but any recommendations on size/brand would be helpful.
Thanks all!
Posted 2018-05-12 8:40 AM (#563226 - in reply to #563222)
Subject: Re: 1958 350 Golden Commando oil question
5000
Hemmings im sure is just looking for suckers... Reselling by slapping a new label on it and marking it up 20%
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3410454/...
lots of options, I used to test my oil by sending it to blackstone labs to determine actual info on engine.
I might do one once I break in my 392 hemi.
Posted 2018-05-12 9:18 AM (#563228 - in reply to #563222)
5000
some info from Castrol about "classic" cars
https://www.castrol.com/en_gb/united-kingdom/products/cars/classic-o...
You can simply use an additive also.
http://www.oldcarsweekly.com/restoration/restoration-tips/new_oil_a...
58Belvedere
Posted 2018-05-13 6:09 AM (#563279 - in reply to #563222)
100252525
Thanks Mike!!
Mopar1
Posted 2018-05-13 11:10 AM (#563292 - in reply to #563279)
2000100025
I look for pre SM oil at yard/estate sales.
Posted 2018-05-13 1:22 PM (#563297 - in reply to #563222)
50001000500
Motor Oil "Wear Test" and "Lab Test" Data - Page 2 - CorvetteForum ...
https://www.corvetteforum.com › ... › C3 Tech/Performance
Aug 24, 2012 - Sooner or later everyone will clue in that Brad Penn oil will protect their daily driver's as well as race engines with no oil related failures.
https://www.penngrade.com/penngrade-1/
http://www.dragzine.com/news/penn-grade-oil-blended-with-zinc-conce...
Posted 2018-05-13 2:32 PM (#563298 - in reply to #563222)
5000
those guys love the brad penn stuff. summit carries it. https://www.summitracing.com/search/brand/brad-penn/part-type/motor-...
okay here is the ultimate "flat tappet" cam oil thread...
https://www.corvetteforum.com/forums/c3-tech-performance/2484100-list-of-flat-tappet-oils.html
Edited by mikes2nd 2018-05-13 2:39 PM
