'57-'59 Dodge/Windsor/Firesweep Frame
   Forward Look Swap Meet -> For Sale - PARTSMessage format
Posted 2018-04-28 3:24 PM (#562431)
Subject: '57-'59 Dodge/Windsor/Firesweep Frame
500020002000500100
I have a 'frame from a '58 Windsor that I don't need. It is free for the taking, but shipping it probably isn't cost effective. It doesn't have any suspension on it, but I have upper and lower control arms available from it too. Rear axle is also available with or without gears in it.
arizona mopar gold
Posted 2018-04-28 3:30 PM (#562432 - in reply to #562431)
Subject: Re: '57-'59 Dodge/Windsor/Firesweep Frame
500
Powerflite, the frames changed in 59...so i think this should be listed as a 57-58 type...in 59 the front suspension was changed ...from bolt on camber plates in 57-58 using shims to 59 welded in plates with eccentric bolt style adjustments...so this frame would be incorrect for a 59
Posted 2018-04-28 3:53 PM (#562433 - in reply to #562431)
500020002000500100
Thanks for the info. I didn't know that about the '59. I just remembered that this frame has the motor mounts cut on it, so it isn't worth messing with. I will just end up scrapping it.
