'58 Plymouth WCFB carb flooding
Chrome58
Posted 2018-04-22 6:07 AM (#562057)
Subject: '58 Plymouth WCFB carb flooding
1000100100100
Hi everyone,
Last week, my car was at idle at a red light and suddenly the engine died. I thought it was an empty gas tank problem (since my gauge is not working), so I put 20 liters (5 gallons) in the gas tank. The engine started with difficulty but died again at idle less than a mile further. Upon opening the hood, I saw that gas had leaked out of the primary carb (I have a 2x4 WCFB config) and onto the manifold. After reading a bit here and there, I'm thinking I might have a case of "carb flooding".
I must say that the 2 WCFB carbs were completely rebuild by a professional during the restoration, a few years ago, and that the primary carb suffered during shipment and ended up with a broken wall at the front (below the "CAR-bure-TER" stamping), but it was completely repaired, and I don't think it's the issue, since I drove the car 750 miles since then.
Anyway, I disassembled the primary carb this morning, and I can't find anything wrong.
The floaters and the needles are OK. But I don't know where else to look.
What should I look for ?
Edited by Chrome58 2018-04-22 10:17 AM
(P1050283b.JPG)
(P1050284b.JPG)
Attachments P1050283b.JPG (210KB - 135 downloads)
Attachments P1050284b.JPG (211KB - 142 downloads)
57plymouth
Posted 2018-04-22 7:31 AM (#562060 - in reply to #562057)
Subject: Re: '58 Plymouth carb flooding
20001000500252525
Sounds like trash in the needle and seat. You already have it apart. Just rebuild it and be done with it.
RUSTORICHES
Posted 2018-04-22 2:42 PM (#562076 - in reply to #562057)
Subject: Re: '58 Plymouth WCFB carb flooding
100100100100252525
I don't really know exactly how you have the carbs set up , but it appears that your primary carb only has the choke assembly (typical) if it's an automatic choke then check your adjustments or in fact the manifold heat riser could be faulty or the choke is sticky.Double check the floats the body of the carb could be warped and as engine heats up the choke may not opening. Here's a website for parts you can check them out I haven't used them yet[ http://www.carburetion.com/WCFB.asp] maybe someone on this forum has and has a review of service.
Edited by RUSTORICHES 2018-04-22 2:58 PM
ronbo97
Posted 2018-04-22 10:25 PM (#562089 - in reply to #562076)
2000200025
How much pressure is your fuel pump putting out ? If it's over 7 lbs, then it could cause this condition.
Ron
Chrome58
Posted 2018-04-23 3:27 AM (#562103 - in reply to #562089)
1000100100100
RUSTORICHES - 2018-04-22 8:42 PM
Yes it's an automatic choke, and it's an electric one I bought off eBay.
The manifold heat riser has been closed, and is not used anymore.
I'll double check the floats.
The body does not seem warped, although I'll double check that as well.
ronbo97 - 2018-04-23 4:25 AM
Interesting lead, but I have no way of measuring the fuel pump pressure ...
Furthermore, everything was working correctly so far, and I'm not sure how the fuel pump pressure could rise suddenly.
Richbo
Posted 2018-07-21 10:25 PM (#566982 - in reply to #562057)
10010025
I am always suspicious of the modern gas eating away at any rubber parts -- even the tiny tip on the inlet needle !!!
Stroller
Posted 2018-10-19 12:50 PM (#571972 - in reply to #562057)
1001001002525
Wow only if my work bench was that clean.
1959 Belvedere Conv
Posted 2018-10-19 10:55 PM (#572013 - in reply to #562057)
<p>I had a similar problem with my dual carb set up in my 59 Plymouth convert (413 RB 2x4 BBL) and it was a bit of dirt in the fuel bowl, just a few specs of black crud that got bye the in-line filter caused the floats to overfill and flood my valley pan under my intake. Cleaned out the fuel bowls and no problem since then. Mine were AFB's but should be the same as WCFB's.</p>
Edited by 1959 Belvedere Conv 2018-10-19 10:56 PM
