dual antenna connecotor needed
57RID500
Posted 2018-04-17 10:20 AM (#561772)
Subject: dual antenna connecotor needed
Hi I'm seeking a dual antenna setup connector. Its for a 1957 Dodge Royal Lancer.
The one in the car, was damaged by someone possibly pulling on it!
Any leads or ideas are always appreciated.
Bob
Posted 2018-04-17 10:35 AM (#561774 - in reply to #561772)
Subject: RE: dual antenna connecotor needed
5000200020005001001001002525
I added dual antennas to my 56 Dodge with supposedly NOS antenna off eBay. In the beginning, I cobbled together a single cable from a 4' cable from Canadian Tire and some coax TV cable. Only one antenna was hooked up to my converted (AM/FM/USB/iPod/BlueTooth) radio. Worked fine.
Subsequently, I was able buy a proper but very used dual antenna cable off eBay. I just did an eBay search on "dual antenna connector Dodge Desoto Chrysler" and found a set of two antenna and the dual connection cable you seek:
https://www.ebay.ca/itm/1961-DeSoto-Chrysler-40IN-DUAL-REAR-NOS-MoPa...
THEN I did a search on "dual antenna connector cable Dodge Desoto Chrysler" and found this:
Snap it up!!
https://www.ebay.ca/itm/NOS-57-58-59-60-61-62-DODGE-PLYMOUTH-CHRYSLE...
Edited by 56D500boy 2018-04-17 10:37 AM
57RID500
Posted 2018-04-17 2:47 PM (#561789 - in reply to #561772)
Subject: Re: dual antenna connecotor needed
great thank you
57RID500
Posted 2018-04-25 9:00 AM (#562253 - in reply to #561772)
radio now works great! thanks for the input and suggestions
