| Looking for a single 57 Plymouth dual quad air cleaner, could also use a throttle linkage.
Edited by mickticulous 2018-03-31 11:17 AM
Location: Perth Australia | To the best of my knowledge, 57 Plymouth used the 2 oval aircleaners, not a single. I believe the 55 and maybe the 56 used the bat wing oil bath type.
As for the linkages, this is what you need if your trying to stay stock, otherwise you can use the setup from summit
http://forwardlook.net/forums/forums/thread-view.asp?tid=44936&post... quad linkage&highlightmode=2#M352456
Location: Newark, Texas (Fort Worth) | This one will work and looks original and at $110 you can't make it for that:
https://www.ebay.com/itm/1966-71-426-Hemi-Carb-Linkage-Plymouth-Hemi...
He is looking for one 57 fury dual quad air cleaner...Wants mine, but now I am looking for a mate, go figure. |
| Mstrug - correct, I have one oval and am looking for a ‘mate’ to make a pair. I have seen that one on eBay and knew it looked right, just wasn’t sure if it was the correct length. I’ll get one if those, thanks.
Edited by mickticulous 2018-03-31 6:39 PM
Location: Brisbane | Im looking for a single 57 fury style air cleaner too lol |
Location: Brisbane | Ive got plenty of 58 dual quad ovals. Pairs and a single if that helps |
Location: So. Cal | I am too, but for a '57 New Yorker. I've found that there are 2 different heights at the carbs. Some are made shorter than others. |
