1960 Plymouth Tag
   Forward Look Technical Discussions -> Fender/VIN Tag and Broadcast Sheet DecodingMessage format
Dracula
Posted 2018-03-12 9:45 AM (#559727)
Subject: 1960 Plymouth Tag
Having just acquired a scrap yard rescue 1960 Plymouth Fury, I'm hoping someone can help me understand the options on the car as I work to get her back on the road.
Edit: I have no idea how to post the darn picture, so I've TRIED to link it...
https://images2.imgbox.com/81/94/m6ufFEcd_o.jpg
Edited by Dracula 2018-03-12 9:48 AM
Posted 2018-03-12 11:06 AM (#559733 - in reply to #559727)
Subject: RE: 1960 Plymouth Tag
500020002000500100
The file was too big. It must be less than 250KB. Please delete your duplicate thread.
(m6ufFEcd_o.jpg)
Attachments m6ufFEcd_o.jpg (230KB - 209 downloads)
Dracula
Posted 2018-03-12 11:47 AM (#559742 - in reply to #559733)
Subject: Re: 1960 Plymouth Tag
I tried to delete the duplicate thread, but it said I didn't have permission.
Chrycoman
Posted 2018-03-17 8:34 AM (#560052 - in reply to #559727)
1000500100100100
Not sure what options belongs to what numbers on the tag, but here goes.
I suspect the car was built at the Lynch Road plant in Detroit. The Lynch Road recorded numbers on the body tag at the top - where all the "1" are located.
The car's serial number should start with -
3 - Car Line / Engine - Plymouth V8
3 - Series - Fury
0 - Model Year - 1960
1 - Assembly plant -
- 1 - Lynch Road, Detroit
- 5 - Los Angeles, CA
- 6 - Newark, DE
- 7 - St.Louis, MO
The last six digits is for the sequential production number. 100221 would be for the 221st car built. The first was 100001.
The tag is generally read left to right, bottom to top. So, bottom row -
SO NUMBER : 10123014 (Shipping Order Number)
1012 - Schedule Production Date - October 12, 1959
3014 - Daily sequence number. The "3" usually referred to different car lines - Hamtramck built Dodges, Darts and Valiant in 1960, for example. Lynch Road built only Plymouths, but had three separate assembly lines under one roof. So, the "3" maybe for the assembly line 3. At Hamtramck Darts and Dodges were built on line 1 and Valiants on line 2.
BDY - 333
3 - Series - Fury
3 - Body Style - 4dr Sedan
TRIM - 123 (Interior body trim)
12 - Style and Upholstery - Bench seat, Cloth and Vinyl
3 - Colour - Caramel
WB3 - PNT - Exterior paint scheme
W - Roof - Oyster White
B - Body - Jet Black
3 - Colour Style - Two tone - roof and scalloped section behind front wheel opening in same colour (Oyster White).
The next section up has a list of letters A-B-C-D-E-F-G-H-I-K-L-M-N-P-Q-R-S-T-V-W-X-Y-Z for the various options available and represented the first two digits of the sales code. The next row with the numbers is the third digit of the sales code.
Have not done enough 1960 Plymouth tags to determine which letter stands for what code group. Anyway, the sales codes for the options we are trying to determine -
A - 3
B - 1
G - 8
Q - 1
X - 3
The list of sales codes ending in the numbers listed -
"3" -
283 - Torqueflite
293 - Power Seats
313 - Air Conditioning with heater
323 - Antennas, rear. dual
353 - 361 V8 (Only optional engine is entered n tag. No engine code ontag means the car has a 318 poly V8 (distributor at the rear of the engine. All other V8 engines are at the front.)
383 - Mirror - outside left, remote
413 - Stone shields
423 - Golden Touch Tuner Radio
"8" -
298 - Door locks, vacuum
348 - Flightsweep deck (false spare tire bolted to trunk lid)
428 - Golden Touch Tuner Radio with rear speaker
588 - Undercoating and hood pad
"1" -
291 - Power Steerng
371 - Light package
381 - Mirror - outside left
421 - Music Master radio
431 - Instrument panel - padded
441 - Tinted glass - all windows
461 - Sun Visors - padded
511 - Windshield washers
Depending upon the car's condition, hopefully most options you should be able to determine if you have them or not.
Hope this helps.
Edited by Chrycoman 2018-03-17 8:45 AM
Posted 2018-03-17 10:55 AM (#560055 - in reply to #560052)
50002000100100100252525
Chrycoman - 2018-03-17 8:34 AM
twotone would be roof and body in contrasting colors. sportone (3) is scalloped section behind front fenders and roof painted same color and body another.
Dracula
Posted 2018-03-21 4:43 PM (#560263 - in reply to #560052)
3 - Series - Fury
- 6 - Newark, DE
- 7 - St.Louis, MO
The Serial number is: 3307103734
Meaning that it came from St. Louis, MO and was the 3,734th car built
BDY - 333
3 - Series - Fury
This matches up perfectly with the car.
A - 3
B - 1
G - 8
Q - 1
X - 3
"3" -
283 - Torqueflite
293 - Power Seats
413 - Stone shields
The car has a push-button Torqueflite as well as air conditioning and a left remote outside mirror; presently, absent, but the cables are still present. The engine is a 318; presently, siezed
"8" -
I do not believe the door locks are vacuum-operated; they appear to be standard mechanical locks. I will have to get the trunk open to ascertain whether or not there is a rear speaker, but there are no provisions for a Flightsweep deck.
"1" -
291 - Power Steerng
371 - Light package
Hope this helps.
The car does have power steering and had an outside left mirror; I'm not familiar enough with the radio to know whether or not it is a Music Master unit.
You have been immensely helpful. Thank you so much.
