Location: calif | can someone identify if this is correct for 57 dodge 2 door hardtop?
if not, then what the correct pn would be?
thanks |
Location: Hay Lakes, Alberta, Canada | Well, the 1957 Chrysler Corporation of Canada Limited Passenger Car Parts manual says that the rear "Window Lift Arms, Sector, And Mounting Plate Assembly" parts numbers are:
-Right 1770 024
-Left 1770 025
I don't see that part number for any of the 57 or 58 regulators, but the number is right in the middle of numbers that are used for regulators. Is it a complete unit, with motor attached? The parts book breaks down each part and doesn't offer a number for a complete assembly. |
Location: Ontario, Canada | Just remember that the Dodge/Plymouth 2 Dr. HT rear regulator doesn't interchange with Convertibles or Anything else! Manual or power.
Greg |
Location: Ontario, Canada | Back in the day when these parts cars were plentiful and cheap, I never found a 57/58 D/P, 2 Dr. HT with power windows. But, I managed to make rear regulators from a 4 Dr. HT..using the manual tracks .It required some machining, cutting and welding and I might have a series of pics if you want. As I recall it required some changes to the inner quarter panel as well but it wasn't a big deal.
Greg |
