Removing sound deadening with dry ice and isopropyl alcohol
Posted 2017-12-29 1:45 AM (#555151)
Subject: Removing sound deadening with dry ice and isopropyl alcohol
5000200020005001001001002525
Bumped into this video looking for something else. Works. I might have used it on my 56 Dodge a) if I had found it before and b) if the original sound deadening was thicker. Be interesting to see if if works on the stuff on the inside of the doors. Thought that I should share the video.
Video: https://www.youtube.com/watch?v=sRh5H43Xs44
What I might have removed before I applied the X-mat (and Dynamat)
Edited by 56D500boy 2017-12-29 1:48 AM
BigBlockMopar
Posted 2017-12-29 10:05 AM (#555162 - in reply to #555151)
Subject: Re: Removing sound deadening with dry ice and isopropyl alcohol
20001000500252525
IMO, there's totally no reason to remove any factory coverings (inside or out) that still have a very good bond with the metal.
Of course it's a different matter if the coating is already chipping and breaking away.
I placed some sound deadening sheets on my '73 Dart from 'Colad' which worked nicely too in taking away a lot of the metal drum sound when you tap on it on larger surfaces.
