M6 Semi Automatic Transmission To 270 V8
tbs427
Posted 2017-12-18 11:05 AM (#554536)
Subject: M6 Semi Automatic Transmission To 270 V8
New User
Hi
I have a customer that we are restoring a 1950 Dodge pickup for.
He purchased a 1955 Super Red Ram hemi for it that he is having built to make 300hp.
His truck is originally a 3 speed fluid drive transmission.
He was reading about fluid drive transmissions and decided he wants to find and use a M6 transmission.
He asked me to come on here and find out if we can bolt a M6 transmission onto his 270 v8?
He also wants to keep it how you shift it on the steering column.
If you have any thoughts or info on how this can be done it is greatly appreciated
jboymechanic
Posted 2017-12-18 11:41 AM (#554542 - in reply to #554536)
Subject: RE: M6 Semi Automatic Transmission To 270 V8
2000100252525
Talk him out of it. If he is building the engine to produce 300 hp, I doubt the transmission would handle it. Also, the transmission would take the fun out of having 300 hp. I know this isn't the kind of "help" you're looking for, but I think he would be really underwhelmed by the transmission if you got the two together.
Edited by jboymechanic 2017-12-18 11:43 AM
LostDeere59
Posted 2017-12-18 4:35 PM (#554561 - in reply to #554542)
100100100100
I had a customer with a 1950 Desoto with a fluid drive and tip-toe shift. I don't know if this is the same trans set-up you are discussing, but if it is I can say that while it was an interesting arrangement, and worked OK once I got it sorted out, I would certainly never take the time to install one where it wasn't originally.
I agree that it would totally eliminate any "fun factor" associated with a high HP engine. In a period correct car it is an interesting and sufficient driveline - I would think behind something modified it would become a liability and an annoyance.
Gregg
wayfarer
Posted 2017-12-19 10:17 AM (#554639 - in reply to #554536)
Subject: Re: M6 Semi Automatic Transmission To 270 V8
500100100100252525
By the time the 270 arrived the M6 was long gone so finding the correct bell to attach the M6 is a long shot. You can ask the guys over at www.p15-d24.com but I don't think that the needed bell exists.
59 in Calif
Posted 2017-12-20 11:06 AM (#554706 - in reply to #554536)
I agree with the rest of these guys. If you can get it bolt up to the 270 he will be disappointed in performance. The M-6 is a 2 speed trans with a overdrive in each gear. 1stspeed is extremely low geared, good for pulling stumps out on the farm. The 53 Chry was the last year to use that fluid coupling/M6 set up. It was great for Grandma to cruise around and not have to shift gears. Jerry
tbs427
Posted 2017-12-20 10:40 PM (#554753 - in reply to #554536)
New User
I'm not too crazy about trying to figure it out something weird myself.
He mentioned someone told him to use a 3 speed manual out of a 1970 dodge.
Do you know what is involved in putting that on a 270 and keeping the 3 on the tree?
wayfarer
Posted 2017-12-21 10:57 AM (#554786 - in reply to #554536)
500100100100252525
A '70 Dodge 3-spd 'could' be used if you can find a 57-60 bellhousing. Right approximate depth for the longish input shaft. Some of the bells have bolt pattern for both the L6 and the V8, makes it easy to identify. Send a PM with an email address if you want a pic of one.
Call Wildcat auto wrecking at 503.668.7786 or Big M auto at 530.473.2225
Be sure to identify which flywheel was used with the bell...146 tooth vs 172 tooth.
Edited by wayfarer 2017-12-21 10:59 AM
