neutral switch
floyd066
Posted 2017-12-10 7:06 PM (#554054)
Subject: neutral switch
10010010025
maybe a stupid question... is the neutral safety switch the same as the neutral starter switch?
Posted 2017-12-10 7:26 PM (#554055 - in reply to #554054)
Subject: RE: neutral switch
5000200020005001001001002525
floyd066 - 2017-12-10 7:06 PM
Maybe. The intent of the neutral safety switch is to prevent you from starting the engine unless the transmission is in neutral. There are ways around that but they aren't safe.
Which car/engine? I can try looking up the PN etc. if it is a 55-58 Mopar
floyd066
Posted 2017-12-10 8:51 PM (#554062 - in reply to #554054)
Subject: Re: neutral switch
10010010025
56 Chrysler Windsor. My book calls it a neutral starter switch. Should be the same.
Posted 2017-12-10 10:28 PM (#554069 - in reply to #554062)
floyd066 - 2017-12-10 8:51 PM
PN 1704 283. Common across the board for Autotrans cars (Plymouth, Dodge,Desoto 55-58 and Chrysler 55-57) and maybe beyond. See parts listing below.
Several options available on eBay:
https://www.ebay.ca/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313...
If you are desparate and very careful, you can bypass the neutral safety switch by putting a short wire on the appropriate terminal of the four terminal starter solenoid and grounding the other wire. I am running that way until I get/take the time to replace the switch on the side of the Powerflite transmission.
My transmission and neutral safety switch:
Edited by 56D500boy 2017-12-11 12:59 AM
(NeutralSafetySwitchOnSideOf1956DodgePowerFliteTransmission.jpg)
(NeutralSafetySwitchPN1704283.jpg)
Attachments NeutralSafetySwitchOnSideOf1956DodgePowerFliteTransmission.jpg (228KB - 149 downloads)
Attachments NeutralSafetySwitchPN1704283.jpg (178KB - 139 downloads)
Posted 2017-12-10 10:44 PM (#554070 - in reply to #554069)
In another neutral safety switch thread from a year ago, 57Chizler said:
57chizler - 2016-12-16 6:28 PM
The NSS provides a path to ground through the internal shift lever (rooster comb); in the pic below the switch/lever combo on the far left is the pre-'64. With a meter hooked to the threaded stud there should be continuity through the switch to the spring-loaded plunger on the opposite end of the switch whether or not the plunger is depressed.
It's actually pretty rare to find one that doesn't work, the usual reason for replacement is fluid leakage where the metal housing crimps onto the threaded stud insulator.
REFERENCE: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=59934&...
floyd066
Posted 2017-12-11 10:11 AM (#554079 - in reply to #554054)
10010010025
Thanks. That's it. Just making sure with the different names.
Posted 2017-12-11 3:47 PM (#554096 - in reply to #554062)
200010005001001002525
floyd066 - 2017-12-10 5:51 PM
Some cars used the Neutral shift button to activate the starter, "start" switch would be different than "safety" switch. These cars also had a vacuum "safety" switch to prevent the starter from engaging -if the Neutral button was pushed once the engine was running.
Confusing terminology.
LD3 Greg
Posted 2017-12-11 11:24 PM (#554133 - in reply to #554096)
57chizler - 2017-12-11 3:47 PM
I agree. I would interpret a " neutral starter switch" to be the one mounted on the trans push button housing. They frequently fail because they are "hard wired" and the wires fall off!
Easy way to tell. How do you start your car? By turning the key or by pushing the neutral push button?
Greg
