Rear window defroster
brdtee
Posted 2017-11-20 6:08 PM (#552794)
Subject: Rear window defroster
10010025
I wonder which years of MoPar rear window defrosters are the same units as 1957. As far as I have seen they look pretty much alike from the 50s to the late 60s.
I have the dash switch, the vent bezel for outlet and the inlet "speaker grille" bezel from 1957 so I would need just the 6x9 blower motor setup, the hose and the duct to complete the defroster.
hemidenis
Posted 2017-11-20 8:07 PM (#552799 - in reply to #552794)
Subject: Re: Rear window defroster
20001000500100100100252525
they are pretty much all the same except for the grille patterns.
Edited by hemidenis 2017-11-20 8:09 PM
brdtee
Posted 2017-11-21 3:27 PM (#552853 - in reply to #552799)
10010025
hemidenis - 2017-11-21 3:07 AM
Just what I have figured out from pictures. So maybe if I try a 1960s Valiant defroster it would pass fine as I do have the correct grille and vent.
Posted 2017-11-21 6:29 PM (#552866 - in reply to #552794)
500020002000500100
I have a '67 Dart setup and it is pretty much the same except the outlet is shorter, so that part would need to be fabbed.
hotrod410
Posted 2017-12-10 4:51 PM (#554045 - in reply to #552794)
Subject: RE: Rear window defroster
I have the complete set up from a '59 Saratoga.
Look at this on eBay http://www.ebay.com/itm/263381094857
Edited by hotrod410 2017-12-10 7:23 PM
FINS!
Posted 2017-12-11 1:49 AM (#554074 - in reply to #552794)
50010010010010025
Just to confirm the Imperial ones are the same. I should have 1 or 2.
