| Hey guys I have recently done some work on the front end and the car is now back together only things missing is the hood and bumper. Now I was wondering if anybody knows the actual ride height of the car as it looks real high.
Location: Southern Sweden - Sturkö island | The ride height is set by the torsion bar adjustments - see "suspension" in your fsm for the correct adjustment. With the correct oem adjustment, the car appears high, but has the best road-ability. |
http://www.imperialclub.com/Repair/Suspension/Specifications.htm
http://www.imperialclub.com/Repair/Suspension/height.htm |
Location: So. Cal | The bumper is quite heavy and is mounted all the way at the front so it will have an impact on your suspension height. I wouldn't worry about measurements until you get that re-mounted. |
| Ok thanks guys I'll measure it all out when I have to all together |
Location: Jamaica Plain, MA | Meanwhile, put some penetrating oil on your torsion bar adjusting bolts. |
