Making New Kick Panels From ABS Plastic Using OE panels as templates
Posted 2017-10-29 10:10 PM (#551302)
Subject: Making New Kick Panels From ABS Plastic Using OE panels as templates
When I got my 1956 Dodge Custom Royal D500 sedan in September 2016, the kick panels were but one of the many things that I knew that I would have to get to and fix/replace eventually. The initial focus was on getting the engine running, then the brakes, then the steering, etc., etc...
Somewhere in there, probably last November, while cruising eBay for all things 56 Dodge, I bought a set of kick panels for a 56 Dodge off an well known eBay seller. When I got the panels, I was immediately disappointed by the fact that they just were a painted cardboard and that they didn't fit all that well when I tried them in the car (I know that day, it was the day I finally had the car running and driving Nov. 25th, 2016).
Along the way, I also acquired a 28" x 36" inch piece of 1/8" ABS plastic that I had originally intended to use to replace my damaged driver's door panel (ended up using hardboard instead).
So today, after "failing" on the new carpet install yesterday (not me per se, the carpet was for a 56 Desoto Fireflite - another story documented elsewhere on this forum), I decided to make new ABS kick panels.
So lacking full original kick panels (the right one was terrible and I threw it out months ago, the left one was around but not full sized), I used the eBay kick panels as the starting point. As needed, I trimmed them with scissors and/or taped on pieces of serial box to create a full fit template to use on the ABS. The left cardboard panel required some trimming and some filling out (up to half an inch on the edge that goes into the kick panel retainer bracket by the door edge (also serves as the windlace retainer in that area). The right panel required a lot of trimming and a little bit of filling out.
Once I had the cardboard kick panels working (actually installed them temporarily to be sure), I traced them on the textured side of the ABS with a silver Sharpy that I happened to have. (If I did have it, I would have put 2" wide green masking tape on the ABS in the approximate location of where the cut was needed and then use a pen to scribe the template).
Once I had the outline, I cut the ABS with my Bosch jig-saw and slightly worn metal blade. Then came a series of trial fits and trims. Because I have a habit of "leaving the line" the ABS was a bit bigger than the template. Better to big and slowly remove material than cut too much and be sorry. Eventually it was close enough that I could shove the back of the new kick panel into the firewall while at the same time warping it enough to get the edge closest to the door into the kick panel retainer.
As the photos below show, the end product looks good. At this point, I plan to paint them a Royal Blue (or maybe cover them with a blue Marine Vinyl ).
Edited by 56D500boy 2017-10-30 1:25 AM
(56DodgeKiclPanelsLeftOriginalDamagedAndNewCardboardModified.jpg)
(56DodgeLeftKickPanelModifiedNewCardboardUsedAsTemplateToTraceOntoABSSheet.jpg)
(56DodgeLeftKickPanelNewPanelCutOutOfABS.jpg)
(56DodgeLeftKickPanelNewABSPanelInPlace.jpg)
(56DodgeRightKickPanelAreaAfterTreatmentWithRustConverterAndZeroRustPaint.jpg)
(56DodgeRightKickPanelModifiedNewCardboardUsedAsTemplateToTraceOntoABSSheet.jpg)
(56DodgeRightKickPanelWithNewABSKickPanelInstalled.jpg)
Attachments 56DodgeKiclPanelsLeftOriginalDamagedAndNewCardboardModified.jpg (244KB - 262 downloads)
Attachments 56DodgeLeftKickPanelModifiedNewCardboardUsedAsTemplateToTraceOntoABSSheet.jpg (175KB - 265 downloads)
Attachments 56DodgeLeftKickPanelNewPanelCutOutOfABS.jpg (225KB - 298 downloads)
Attachments 56DodgeLeftKickPanelNewABSPanelInPlace.jpg (241KB - 271 downloads)
Attachments 56DodgeRightKickPanelAreaAfterTreatmentWithRustConverterAndZeroRustPaint.jpg (174KB - 268 downloads)
Attachments 56DodgeRightKickPanelModifiedNewCardboardUsedAsTemplateToTraceOntoABSSheet.jpg (226KB - 293 downloads)
Attachments 56DodgeRightKickPanelWithNewABSKickPanelInstalled.jpg (228KB - 268 downloads)
brdtee
Posted 2017-11-22 7:41 AM (#552911 - in reply to #551302)
Subject: Re: Making New Kick Panels From ABS Plastic Using OE panels as templates
1001002525
Looking good!
I have the same work ahead, still not sure what material to use but I was at first thinking a thick waterproof cardboard that they use in advertising signs and cover it with thin vinyl before painting it with black matching the door panel.
One thing I'm still uncertain is whether to have a layer of soundproofing material on the back side of the kick panels and door panels.
Posted 2017-11-22 11:04 AM (#552923 - in reply to #551302)
5000200020005001002525
I like it too. Although, I am planning to mount speakers there first.
Posted 2017-11-22 12:14 PM (#552928 - in reply to #552923)
The material that they typically use for signs is Coroplast, a corrugated plastic product. I think it is too thick to work as a kick panel material.
brdtee
Posted 2017-11-22 12:47 PM (#552931 - in reply to #552928)
1001002525
56D500boy - 2017-11-22 7:14 PM
Yes this is def. too thick material. There are variety of different materials available, I was referring to a non-corrugated thick cardboard which is waterproof and only about 2 mm thick. Been using that on some event signage myself.
Posted 2017-11-22 1:29 PM (#552933 - in reply to #552931)
brdtee - 2017-11-22 12:47 PM
The ABS I used was 1/8" thick (about 3 mm). One side was shiny smooth and the other has a "leather"-like texture.
Posted 2017-12-15 12:43 PM (#554387 - in reply to #552933)
Yesterday in a 57 Chrysler thread, I joked about the two-tone kick panels in the 57 and then made another joke about maybe trimming my new ABS kick panels like that. Today I found a photo of a 55 St. Regis and those bashtards stole my design!!! I was only 2 in 1953 when they did the design and I didn't reveal it until 64 years later but hey they stole my design. LOL.
The 57:
My idea (revealed yesterday after incubating for 64 years):
The 55 St. Regis - even has the stainless strip (who knew?)
Posted 2017-12-16 5:38 PM (#554425 - in reply to #554387)
Found another trimmed 55 Chrysler kick panel photo at allpar
Edited by 56D500boy 2017-12-16 5:40 PM
(1955_Chrysler_NewYorkerDeluxe-hardtop_dashboard_kickpanel_large.jpg)
Attachments 1955_Chrysler_NewYorkerDeluxe-hardtop_dashboard_kickpanel_large.jpg (245KB - 245 downloads)
coronetx2
Posted 2017-12-17 7:31 PM (#554506 - in reply to #551302)
100252525
I did my 56 dodge kick panels with black sheet ABS plastic a couple years ago worked great.
Also used it to make the headliner panel for my 61 Plymouth Fury.
Used a heat gun to mold/form them and then bonded perforated vinyl on them it worked very well.
Posted 2017-12-17 7:39 PM (#554508 - in reply to #554506)
coronetx2 - 2017-12-17 7:31 PM I did my 56 dodge kick panels with black sheet ABS plastic a couple years ago worked great.
Also used it to make the headliner panel for my 61 Plymouth Fury. Used a heat gun to mold/form them and then bonded perforated vinyl on them it worked very well.
That was brave of you to tackle the Fury headliner in ABS. The stuff I had was pretty stiff.
Did you cover the kick panels in vinyl or just paint? How have they stood up?
coronetx2
Posted 2017-12-18 4:30 AM (#554527 - in reply to #551302)
100252525
I left them black door panels are black and white and the carpet is black.
When I did my 56 lancer I was on a very tight budget
Posted 2018-04-26 2:23 AM (#562295 - in reply to #554508)
While I am in the final stages of installing my carpet (so I get the seats back in the car), I have gotten back to the kick panel project.
Using this as my "guide":
I am going to use two of my extra pieces of armrest trim to create the "chrome" divider bar.
This:
(56DodgeABSKickPanelWithHalfInchMaskingTapeToMarkTheChromeBarLocation.jpg)
(BackSideOfArmRestTrimAndABSKickPanel.jpg)
(ArmRestTrimLayingOverTheHalfInchMaskingTapeLocationMockUp.jpg)
Attachments 56DodgeABSKickPanelWithHalfInchMaskingTapeToMarkTheChromeBarLocation.jpg (195KB - 255 downloads)
Attachments BackSideOfArmRestTrimAndABSKickPanel.jpg (234KB - 248 downloads)
Attachments ArmRestTrimLayingOverTheHalfInchMaskingTapeLocationMockUp.jpg (227KB - 251 downloads)
Posted 2018-05-28 10:44 PM (#564146 - in reply to #562295)
Finished off the carpet install and before I put the front seat in, I added the vinyl to the previously painted right front ABS kick panel. Then I added a section of straightened armrest trim at the joint between the upper painted area and the lower vinyl area (vinyl is the stuff I am using when I redo the door panels). Looks like despite my best efforts getting the trim lined up with the door panel trim, I will have to adjust the "new" kick panel trim at bit. However, in general, it looks fairly close to my original concept though so I am happy enough.
Photos from today:
Edited by 56D500boy 2018-05-28 10:47 PM
Posted 2018-05-29 11:17 AM (#564165 - in reply to #551302)
Looks really good. I am wondering if I could adapt a newer molded carpet to the car instead of dealing with this cut & sewn stuff that doesn't really work that well.
Posted 2018-05-29 11:35 AM (#564167 - in reply to #564165)
Powerflite - 2018-05-29 11:17 AM
Cut and sewn probably works better when the set you receive is actually supposed to fit your car, i.e. a 56 Plymouth, etc. NOT a 56 Desoto into a 56 Dodge.
