61 Chrysler headlights
anth61
Posted 2017-10-14 5:44 AM (#550274)
Subject: 61 Chrysler headlights
All 4 headlights work when the high beams are on but only one side works when in low beam mode.
Any ideas on diagnosis?
StillOutThere
Posted 2017-10-14 5:58 AM (#550275 - in reply to #550274)
Subject: Re: 61 Chrysler headlights
2000100010010025
You either have a bad bulb or a bad wire or connection to the bulb. Remove the bulb and check it direct to the battery. The center post is the ground. The other two are high and low. If the bulb works, check the corrosion inside the plug that goes on it. If that is clean, ck power at the terminal block. Simple diagnostics. It is not a switch problem on the dash or you would not get one bulb to light low beam. Same, it is not the high beam switch on the floor.
Ev's62Chrysler
Posted 2017-10-14 8:31 AM (#550281 - in reply to #550274)
100100
Both bulbs on the side without low beams might be bad. Swap two side to side and see if the problem follows the bulb.
Posted 2017-10-14 9:48 AM (#550284 - in reply to #550274)
Low beam element is probably burned out in the bulb not working on low beam.
anth61
Posted 2017-10-16 7:08 AM (#550374 - in reply to #550274)
Subject: RE: 61 Chrysler headlights
so i swapped both low beams and noticed the the same globe not working on the opposite side but the other was...thats telling me i need a new low sealed beam.
thanks for your help guys.
Edited by anth61 2017-10-16 6:31 PM
