flasher location on a 57 Fireflite
dlyle
Posted 2017-10-04 3:54 PM (#549763)
Subject: flasher location on a 57 Fireflite
10010025
I cant find one in my car but must be looking in the wrong spot. Can anyone provide a picture of where the flasher goes? Is it round or square and does it snap in place or is it screwed or bolted in? What side of the column is it on?
As big as this car is it sure is crowded under that dash.
Don't have working turn signals. I've made sure all the bulbs work and so now want to try a new flasher.
dlyle
Posted 2017-10-04 4:57 PM (#549766 - in reply to #549763)
Subject: Re: flasher location on a 57 Fireflite
10010025
I found it. Was very difficult to find but finally did. This is what it looks like. Couldn't get a picture until I got it out.
(IMG_5619 (2) (500x375).jpg)
Attachments IMG_5619 (2) (500x375).jpg (89KB - 177 downloads)
Posted 2017-10-04 7:26 PM (#549781 - in reply to #549763)
Subject: RE: flasher location on a 57 Fireflite
500020002000500100
If you ever want to try your hand at using LED's , or possibly to light up both rear lights at the same time, I recommend that you get a digital flasher.
(DualLights.jpg)
Attachments DualLights.jpg (51KB - 156 downloads)
dlyle
Posted 2017-10-04 10:31 PM (#549789 - in reply to #549763)
10010025
I did get am EL 12 flasher for it today which is elcetronic. Does it cause problems using the original flasher and two lights coming on in the back for brakes or signal? My lights are already wired so that tops and bottom come on. Not sure that I will leave it that way though. Maybe that is contributing to the gremlins I'm seeing.
It does seem a bit strange to only have those tops likes on at night (unless signaling or braking).
Edited by dlyle 2017-10-04 10:35 PM
macedon
Posted 2018-05-04 1:00 PM (#562800 - in reply to #549781)
5001001001001002525
Powerflite - 2017-10-04 6:26 PM
Can you share the way you wired this change? Looks awesome.
Posted 2018-05-04 1:27 PM (#562802 - in reply to #549763)
500020002000500100
Sure. My original thread about it has a lot of false starts and trial & error on it, and I don't really explain well what I did. But this later thread shows it in more detail without the trial & error.
http://forwardlook.net/forums/forums/thread-view.asp?tid=63589
Edited by Powerflite 2018-05-04 1:29 PM
