door removal
fireguyfire
Posted 2017-10-01 12:50 PM (#549530)
Subject: door removal
1002525
Going to remove all 4 doors on my 58 chrysler to start the body restoration; obviously removing the doors themselves are easy, but I am wondering how to go about disconnecting the door straps that keep the doors from swinging to far open; looks like the keeper pins in both ends ar rivented into the pivot brackets, and the brackets are riveted into the A and B posts.
I couldn't find any references in the shop manual, so hoping someone can help me out before I start trying my ideas and perhaps bending or breaking something.
Old Ray
Posted 2017-10-01 1:03 PM (#549531 - in reply to #549530)
Subject: RE: door removal
500
Until corrected and suitably punished, it is my understanding that the pivot rivet head needs to be ground off (at the bottom if looks are important or on top if the belly or arthritis requires so) and replaced with a small machine screw and nut or a cotter pin(?) or a new rivet (not avaliable OEM).
Edited by Old Ray 2017-10-01 1:04 PM
Posted 2017-10-01 6:42 PM (#549551 - in reply to #549530)
Subject: Re: door removal
500020002000500100
Correct, you have to grind off the the rivet.
fireguyfire
Posted 2017-10-01 6:51 PM (#549552 - in reply to #549530)
1002525
Thanks gents; got the 4 doors off easily.
